Dish gets stuck under the roof bars
Discussion in 'TV & Satellite' started by alanjenkins, Jun 7, 2014.
  1. alanjenkins
    alanjenkins Read Only Funster
    Jun 7, 2014
    5
    Essex
    Is it a broken dish or is there an easy fix?
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,803
    6,064
    Mansfield,Notts
    Yes, it should not do that
    Come on give us a clue:RollEyes:
  3. alanjenkins
    Jun 7, 2014
    5
    Essex
    It moves around as if it is having difficulty finding South then the arm finds its way under the roof bars, it jams and grinds to a halt and the only fix is to get on the roof , remove the bars and help it along. Not ideal!
  4. hilldweller
    Dec 5, 2008
    27,567
    26,682
    Macclesfield
    Why not just eat at ground level ?
    • Like it Like it x 3
  5. Geo
    Jul 29, 2007
    9,803
    6,064
    Mansfield,Notts
    Seems an obvious statement, but it appears from your description the system has been fitted in the wrong place, the only other reason would be the arm is not located properly??
    Im sure you understand and it is usual practice that an Auto dish requires 360 degree clearances through out and full up and down range without banging into roof fittings
    Pictures would help us help you
    PS have you ever had a picture with this set up or is it new to you?
    • Like it Like it x 1
  6. alanjenkins
    Jun 7, 2014
    5
    Essex
    It used to work fine which is what is so confusing.
  7. alanjenkins
    Jun 7, 2014
    5
    Essex
    Picture attached - It is the black bit at the end of the arm that goes under the rails and jams
  8. Geo
    Jul 29, 2007
    9,803
    6,064
    Mansfield,Notts
    Ok My opinion for what its worth
    1. The Sat installation position is poor, this scenerio should not have been allowed to happen
    2. Whats gone wrong? I believe the Sat can and will again work properly.
    when it knows where to look for the satelite, it seems to have lost its bearing
    and is now looking in places it has never had reason to before.
    Thinking about your problem the only way the arm can catch the roof rails is when searching round and round with the dish almost pointing at the roof and it aint going to find a satellite on yer roof is it:Doh:, Unless NASA have had a mishap they dont want to tell us about:Eeek:
    Me thinks you need to try totaly depriving the control box of electrickery (Unplug It) and set it of again for a search with you on a ladder to assist it past the obstruction in its quest.
    If it then fails to lock on
    It may be due to the recent moving of the Satellite position and need re programing
    I dont believe its broke, its poorly fitted and just like little Brian on the TV its a computer and a little confused, (Ok wrong insurance company):Rofl1: Sorry small person:Doh:
    It just needs a Hard Re Boot up the backside or a re program and once trained again in its purpose in life wont go near the roof rails agin
    PS Sad I know but I went to sleep pondering this problem and hopefully woke up with the answer
    Good luck
    Geo
    More simple answer
    Alternatively the arm it's self is broken and not lifting correctly with the dish, it should be about 30 degrees on an upward slope away from the dish when the dish is about straight up and of course miss the roof rails
  9. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    I have never had a roof mounted dish, so I do not know what is wrong with yours, the only thing I can think of it,s not what others have said, could it have moved ?. Pete
  10. 1Oll
    1Oll Read Only Funster
    Jan 12, 2010
    175
    86
    Cheshire
    Set minimum search height.
    My Oyster sat system can be programmed not to search too low . So it won't hit my skylights on my Amethyst.
    B.
