Digital Feeview through RV Aerial (1 Viewer)
M
Mayurua
Does anyone know if Digital TVs with freeview work ok using American RVs Aerial
Thanks Dave
43,315
49,369
have a read of this thread.....may be of some help. Link Removed
take note of the post regarding turning the booster supply on.
personally i dont think they will work on a purely digital signal but will work on the current anologue/digi signal.
depends if your area has changed over to digi yet.
damondunc
Aug 2, 2007
101
15
near Lincoln
rv aerial
assuming you are talking about the winegard sensar aerial, when set up correctly it works very well with freeview boxes, if it doesn't work correctly there are 1 or 2 common faults.
We run 2 boxes off one aerial with no problem at all, you do have to be in a good signal area, with digital it either works well or not at all, stratford is a good example at the motorhome show, virtually no signal at all.
Dunc.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
current power levels are fluctuating, at home we go from 100+ channels one day to 20 the next power levels drop every evening, when we eventually turn digital instead of a mixed system we hope power levels will increase. Until then a preamp for the correct frequencies is a must. Good luck to us all. Personally I think it will result in an unreliable terrestrial service.
nozzel
36
Birmingham West Midlands
C Class & RV US
43 years
Digital
Hi We're receiving a crystal clear digital picture on an RV aerial here in the US
Nozzel
