Diesel leak on '07 Fiat 2.3 ducato (1 Viewer)
Wildge
1,762
1,980
East Midlands
Coach built.
since 2000
Anyone have ideas on heavy diesel leak , actually pouring from engine...... on pulling onto campsite 2 days ago (not a techie but ? from filter). As always happens... after calling out the breakdown.... no sign of leak apart from heavy diesel fumes throughout the site. :Sad:
(Had timing belt change , new water pump and service in September and used van extensively since then).
Started engine today no further signs but am about to move on tomorrow?
monk
24
4
Fairburn North Yorkshire
since 2011
Try looking at the diesel filter seal the rubber seal gave in on my 2.3 multijet 2 weeks after the service so the garage replaced it FOC and its been ok since then .
Chris
21,053
278,715
None
10 years
This happened to me a few years ago in Spain.
The staff at Las Dunas in Spain went apeshit when I rolled up with diesel spewing out.:Doh:
It was the fuel filter. A local Fiat mechanic came to us and sorted it out. He said it wasn't a genuine Fiat part.
Since then we have always insisted on Fiat parts and had no further problems.
monk
24
4
since 2011
Now I remember that was the reason my filter failed it was cheap part the garage fitted.
DuxDeluxe
14,658
72,771
Planet Zog
A woosh bang van
since 2008
Common problem - mine failed, the RAC guy temporarily fixed it and then it just entire again. The seal does not seem to be up to the job, sometimes.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
If they do not use the proper tool it will leak or break the plastic make SURE the garage has the right tool and uses it
Broken Link Removed
rainbow chasers
3,680
1,725
Mid Cornwall
Various
They had a recall on the fuel rail IIRC - make sure that hasn't ruputured. Also check the filter seal i recently serviced.
W
Wildge
1,762
1,980
East Midlands
Coach built.
since 2000
diesel leak
Thanks for all your comments guys...............have moved............(with everything crossed) to new site. Just hope to get home without further..............????? and solve problem :Doh:
Thanks again.
tonka
10,830
21,527
Cannock, Staffs
A class Burstner 800
Since 2000
Just to back up what others have said..
We went off to Germany a week after having a major service, while there stopped at a supermarket and Diesel spilling out.. Breakdown came and it was the fuel filter, appears that on the service they could not have done it tight enough.. !! That was a main fiat delaer / motorhome company.. Chelston!!!
The ADAC guy retightened it and it was fine for the next 18 months, when i sold the van..
MHVirgins
3,889
3,158
South of Scotland
March 2011
We had a similar problem two days after collecting our Autotrail Dakota from the dealers during the summer. Diesel leaking out and dribbling everywhere, you won't notice it quite the same when the engine's not running. We drove over a hundred miles up the A1 with it leaking, but didn't realise what the problem was at that point. It had just been serviced before we collected it, however, by the time we reached Wensleydale we discovered what the problem was.
We got a local mechanic out to look at it, he didn't have the correct tool for the job and as Jhorsf said this must be used to do it properly.
Eventually the dealer sent up their own mechanic to sort it out for us, they offered to replace the whole unit, but said that it was the seal that was the problem. Our dealer was Oaktree Motors and they sorted it out and we've had no further problem with it.
The mechanic said the seals were notorious for being faulty and flatten easily.
Bill
