Diesel heater problem (2 Viewers)
octopush
147
54
portsmouth
coachbuilt
2days
Can anyone help.
I have a diesel heater problem.
I switched the heating on in my motor home the other day to see if it worked and it did for about 5 minuets lots of heat, Then the van filled with smoke from all the open outlets so i switched it off and now nothing at all happens when switch on.
I have not had a look to see what has gone wrong yet but will do later this week.
I was wondering if anyone else has had this happen and could give me a clue as to were to start looking.
Thanks Rob
DBK
18,017
48,064
Plympton, Devon
PVC, Murvi Morocco
Sounds serious, I wouldn't have thought there is any way the combustion side should be able to reach the blown air side. What type of heater is it?
octopush
octopush
147
54
portsmouth
coachbuilt
2days
I was thinking the same.
I think it is a Webasto i will have a look when i get home
DBK
18,017
48,064
Plympton, Devon
PVC, Murvi Morocco
Webasto have quite a good technical support line. I have heard of people being talked through problems by them, resetting fault codes etc. If it is a Webasto give them a ring.
Nov 30, 2009
6,545
148,944
Pickering
PVC the PUG
When we first got our MH , we were away in it and the normally quiet Webasto ( unless on start up :RollEyes:) started making a right racket. Compared to normal . The Motorhome hadn't been used for quite a long time. Before we bought it.
We turned it off , worried. It wasn't that cold anyway. We were just trying it out. Anyway after a trip back to the dealer on our return , it turns out it was only the self cleaning system thingumyjigs . It does it every once in a while to self service it or something like that...
There was never any smoke though.
lee52
327
119
tyne and wear
selfbuild
newbie
was the smoke diesel smoke? I had one pumping smoke out off the outlets there was (well I think) a nest in the outlet of the heater up against the combustion chamber and once it got to full temp it started burning the nest . has it been unused for a long time
