Diesel heater plug fuse (1 Viewer)
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Anyone know where the Fuse for the Diesel Heater Plugs is? Not the one in the Vehicles Glove Box, this one is (and I'm not sure of the tech term to describe it) about 30mm long, metal, with a hole each end, which you place between two terminals, abit like the fuse between the charger and the Leisure Battery.
The Vehicle is an 02 Fiat Ducatto 1.9 TDI
Do I have to go to a Fiat agent to get them?
All help gratefully received as always
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Its possible that you have a bank of fuses bolted directly on to the positive battery terminal, On the 2.8 engine there is such a thing, they are all high amperage fuses but I have no idea if the one you are looking for is there, but its worth a look.
Doug...
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
on some fiats they are on the battery terminal itself on a sort of plate fastened to the terminal:thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Link RemovedHave you found the fuse ? was it on the battery plate?
rangi
Jun 30, 2010
7,924
27,229
Cornwall
View attachment 9059Have you found the fuse ? was it on the battery plate?
Mate! Manana! been busy gathering and freezing or pickling the black currants, potatoes, cabbage, beetroot, shallots et al, which have blossemed since we been away. Tomorrow will get into the M/H, (After doing a brew bottle) will post then M'ansome:thumb:
Douglas
2,835
400
South Wales,
Never mind about the fuse, I want to know how you are harvesting beetroot's and shallots so early, mine are only just starting to swell and I'm not that much further north than you.
Doug...
rangi
Jun 30, 2010
7,924
27,229
Cornwall
Doug...
Cornwall M'ansome:thumb: Gods Little Acre:thumb:
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
this should be from 2002 model? look at number 2 on picture the fuses bolt to this and it is on the + terminal al this should be under battery cover (item number 3) on picture
naread.exe
subcategory: 55300/00 - BATTERY (Tab:1/4)
compatibility: None
PROD. CODE FUR. DESCR. COMP. MODIF. QTY N. C. C. R.
1 BATTERY
71719455 60AH-320A 01
71719456 70AH-400A 01
71718462 88AH-580A 01
71719457 100AH-470A 01
71719458 100AH-650A 01
2 CENTRALINA ELETTRONICA
1338074080 M1 ,M2 01
1339306080 M5 ,M7 01
1339014080 309(M1 ,M2 ,M5 ,M7 ) 01
1339307080 025(M5 ,M7 ,M25 ,M26 ) 01
1339013080 025+309(M5 ,M7 ) 01
1339307080 M10 ,M11 01
1339013080 309(M10 ,M11 ) 01
1339308080 025(M10 ,M11 ,M15 ,M20 ,M22 ) 01
1339015080 025+309(M10 ,M11 ,M15 ) 01
1339015080 025+309(M20 ,M22 ) 01
1339309080 M15 ,M20 ,M22 01
1339308080 089(M15 ,M20 ,M22 ) 01
1339013080 309(M15 ,M20 ,M22 ) 01
1339308080 M20 +007 01
1350981080 4GV(M10 ,M15 ,M22 ) 01
1350982080 4GV+025(M10 ,M15 ,M22 ) 01
3 COVER
1331260080 01
4 BRACKET
1346213080 GS (M1 ,M2 ,M5 ) 01
1346213080 GS (M7 ,M10 ,M11 ) 01
1340379080 good (M1 ,M2 ,M5 ,M7 ,M10 ) 01
1340378080 good +009(M5 ,M7 ,M10 ) 01
5 BRACKET
1339461080 GS 01
1333585080 good 01
6 BRACKET
1338470080 GS (M10 ,M11 ) 01
1339062080 good (M1 ,M2 ,M5 ,M7 ,M10 ) 01
1339061080 good +009(M1 ,M5 ,M7 ,M10 ) 01
1338734080 GS (M1 ,M2 ,M5 ,M7 ) 01
7 ELECTRIC CABLE
1335551080 C6528 01
1341769080 D6528 C10446 01
1346568080 D10446 01
1350228080 4GV(M10 ,M15 ,M22 ) 01
8 CLIP
7725349 01
9 RELAY
46520412 12V-30A 01
10 CUP
1339022080 GS +025(M10 ,M11 ) 01
11 CLIP
1338042080 good (M15 ,M20 ) 01
12 BRACKET
1339456080 GS +M15 ,M22 01
13 CLIP
1338208080 GS +M15 ,M22 01
14 CLIP
82436759 GS +M15 ,M22 01
15 BUTTON
7715590 02
16 SEAL GASKET
1337763080 02
17 FUSE
10404090 60A 01
10404190 70A 01
10404290 80A 01
10404390 100A 01
10404490 125A 01
18 FUSE
11056390 150A 01
19 SWITCH
60668852 309 01
20 BRACKET
1324432080 M1 ,M5 ,M7 01
21 SCREW
13838814 M1 ,M5 ,M7 01
1/4
55300/00 - 1 2/4
55300/00 - 2 3/4
55300/00 - 3 4/4
55300/00 - 4
