Diesel Cap On Fiat Ducato
Discussion in 'Motorhome Chat' started by juhso, Jun 3, 2015.
  1. juhso
    juhso Read Only Funster
    May 30, 2015
    3
    3
    Kinghorn
    Just driven home in my newly purchased 2005 Auotrail tracker - Everything works fine except
    the lockable cap to the diesel. I eventually got it open using the ignition key but now can't lock it - its just stting in very loosely with a good chance that the first bump will doslodge it.
    Is there an easy answer to this or should I nip into a garage and get an unlockable one...?
  2. Steve devon
    Steve devon Funster
    Sep 7, 2014
    212
    167
    It's a common fault, fiat parts on line will sort it out, get a new one
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,946
    12,200
    Plympton, Devon
    Put some light oil on the key and lubricate the lock. I find the cap has always been a bit awkward. On mine you have to hold the black plastic bit and then turn the key clockwise. You can't do it one handed.
    • Like it Like it x 1
  4. IanF
    IanF Funster
    May 7, 2013
    2,199
    650
    Redcar- N.Yorkshire
    We got a 2005 Lunar Roadstar on Monday this week and like you struggled to get diesel filler cap to relock . It took a bit of repeat trying to get it locked but it can readily be done I assure you although it does not seem possible on first try. Hope you can do it too.
    Ian
  5. CWH
    CWH Funster Life Member
    Jan 29, 2014
    3,104
    13,514
    under a wand'rin' star
    We've had ours nearly 18 months now and only just getting the knack of the diesel cap!
    When we picked the van up we went to the gas station (practically next door) to fill up and blocked the forecourt for a good 10 minutes or more trying to get the cap off - I think if they weren't anticipating a big sale they'd have asked us to leave!
  6. juhso
    May 30, 2015
    3
    3
    Kinghorn
    Many thanks to you all for your quick replies. gratified, but saddened too, that I am not alone. We're off up to Ullapool tomorrow so don't fancy losing half a tank en route!
  7. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,889
    1,773
    Cornwall
    On a similar theme I wonder if anyone can shed light on this 'filler cap' question.
    A couple of days ago I put fuel in our 'van.
    It's been some time since we did so, (No I haven't discovered the secret to everlasting diesel) and when I unscrewed the filler cap I definately released a partial vacuum in the tank. You could hear the air going in.
    Is this normal and if not, by having the creation of a partial vacuum in the tank am I in some way creating a possible problem.
    All answers gratefully received.
  8. John Laidler
    Jan 9, 2013
    8,946
    12,200
    Plympton, Devon
    I've noticied that and I think it is normal. I can only guess the tank is not open to the atmosphere but does so through some sort of pressure relief valve. Probably a safety or environmental thing.
  9. mick noe
    mick noe Funster
    Apr 14, 2009
    615
    523
    near Boston Lincolnshire
    mines the same odd is it not? be interested in answer myself as you would think it would stop fuel eventually
  10. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,738
    10,161
    a few drips of oil in the lock mechanism then work it open and closed several times to loosen it does the trick normally. and the rush of air when removing the cap is normal
  11. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,179
    3,014
    Kendal, Cumbria
    Are you sure it's air going in - rather than coming out? Fuel tanks normally have a valve to admit air but prevent it from escaping so a rise in temperature can cause a small build up of pressure in the tank which is released when the filler cap is removed.
  12. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,889
    1,773
    Cornwall
    Thanks to a lifetime's experience......
    I can tell the difference between a suck and a blow:giggler:
    • Like it Like it x 2
  13. Gorse Hill
    Gorse Hill Funster
    Feb 2, 2013
    1,742
    1,716
    Stretford
    As DBK has said its a two handed job, I had the problem myself when I first got the van
    Hold the cap with one hand and turn the key with the other, have a practise today before you fill up
  14. trophychap
    trophychap Funster
    Dec 24, 2009
    730
    5,726
    bedworth warks
    Both the x250's I have had have definitely sucked air into the tanks when I have removed the filler caps. Years ago most cars/vans had a small air hole in the caps, it seems they don't now.
    My MGF is the same a definite suck in when the cap is removed. I wonder if it has anything to do with the fuel tanks being made from plastic these days?
  15. Kool Kroozer
    Kool Kroozer Funster
    Apr 19, 2014
    1,220
    2,034
    Cannock Staffordshire
    You really would think with today's technology of the 21st century that some baffoon could design something as simple as a lockable fuel cap without it having problems - The fuel cap on our Citroen DS3 i must say is awesome, it looks the same design as the camper vans cap but you just put the key in the cap and turn it to unlock and the whole cap just comes away with the key - all done with one hand, how long it will be good for is anyone's guess :LOL::LOL:
  16. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,752
    2,688
    Tunbridge Wells
    Its a Citroen so probably now a matter of days.
  17. trophychap
    trophychap Funster
    Dec 24, 2009
    730
    5,726
    bedworth warks
    I've got a 2006 C4 with the same petrol cap, still working perfectly fine.
  18. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,161
    1,265
    Dronfield - Derbyshire
    I curse that filler cap every time I have to use it. The flap opens the wrong way, you cant get your hands in ( you need both) because of the vans width and all the while you are squashed up against the pumps.
    Vacuuming fuel tank is common system now.
