Did you know this? (1 Viewer)
etap
256
228
Somerset
Chausson Flash 610
3 years
In our new MH 2015 there is a grill which we have used occasionally, reading through the instruction book yesterday I found out (probably you already know, we didn't ) that when using the grill the door should be at least half open or fully open but never closed.
One would have thought that we should have been told at the handover.
A thought, why is there a door if it is not used, is it just to stop things falling out of the grill?
Carol
14,048
111,946
North Wales.
You should never shut the grill door when it is in use, either in the house or the motorhome, if the door is shut when in use it virtually becomes a oven which it is not designed to do and dangerous I would think.
It probably was not mentioned in the hand over because it is written in the manual.
jnn
250
684
cheshire
van conversion trafic
nooby
101 of learning to cook is leave the grill door open when on, suspect it would have been presumed. Although have to admit with my current (electric) cooker I tend to close it as it's the oven too and seems happy closed
Dec 29, 2012
505
30,697
Cheltenham
Rapido 7066df
Since 2014
When using the grill function on our Rapido oven, the flame goes out if the door is closed. Mind you, we did find this out the first time we tried to make toast :)
Zigisla
2,576
3,101
Gosport, Hants
Sunlight A72
Getting better month by month.
Doesn't closing the door cut the gas supply off as well so you cannot use it?
Jan 3, 2008
3,335
5,354
Pakefield, Lowestoft, Suffolk, UK
Looking
You nearly suffered whats known as an RTFI fault, it van happen to all manner of appliance and equipment. I will leave you to work out what that means.:)
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
I think most of the SMEV ovens have a slide out metal flap(?) inside the top of the oven to keep the heat away from the fittings above the oven (and keep the door open).
etap
etap
256
228
Somerset
Chausson Flash 610
3 years
So most of you know including my other half, I must stop reading about things I know nothing about.
Yes there is a baffle plate on ours Bob.
Aug 18, 2014
23,730
133,001
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yes our gas cooker also has a plate that is put in place when the door is open to use the grille to stop the knobs melting. :LOL:
Chris
21,042
277,576
None
10 years
Crikey, even I knew that:)
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
As far as I knew the door has to be down as with the grill at home. Actually, why would you want to put something under a grill and close the door. It's not an oven. However, I suppose this is something you either know or don't and I certainly wouldn't knock anyone for not knowing. There's a lot of things I don't know and this is where this forum is so very invaluable.
I also didn't know that, until Phil of Rhino Installs told me, that the gas switches off if the lit gas blows out. Apparently (and this is the technical area I know nowt), it's the flow of gas and lack of heat so cuts off. May not be totally correct so don't take the mickey but apparently ours works correctly.
Debs
6,293
181,129
West Notts
A class Adria Vision
I've just read all this, wondering whether I leave the door open ????
Penny has just dropped as to why I couldn't remember.....
Our tec tower is only an oven, no grill .....phew.....!
:doh:
movan
21,492
120,753
Moving around
Burstner
since07
I knew that .. dah de dah I knew that!!! :) :)
There's a first for everything.:clap2::clap2::clap2:
Northernraider
27,358
176,567
On the sofa ....
Mobilvetta eurayacht
On and off since 95
Thank goodness for school cookery classes I knew that one.
Although there are some strange things, the heating instructions for my van recommends that the windows or skylights are left slightly open when heating in use..... Seems bloody mad to me
