Dethleffs A Class headlamps
Discussion in 'Tech/Mech General' started by talaris, Nov 13, 2012.
  1. talaris
    talaris Read Only Funster
    Aug 17, 2012
    89
    25
    Cornwall
    For those with a Dethleffs A Class probably 2008 on I wondered if your headlights actually flashed. i.e with lights off when you activate the flasher stalk in the cab do the lights come on and flash
    The solenoid is working as you can hear it as the falsher is operated?
    Mine don't flash and I am told that they do not work on A class Dethleffs.
    Is that right?
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,116
    17,785
    YO11 2BD
    dont know for sure but i would say yes, they should flash.
    the builders will use the standard chassis/cowl with most of the wiring already intact.
    it could be they altered the dashboard/steering column wiring but i doubt it.
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,779
    10,192
    although you hear the relay click, the power is not being passed to the lights. either a blown relay or wiring fault which should be easy enough to trace back from the light main beam circuit.
    i assume the lights do work on main beam normally?
  4. talaris
    Aug 17, 2012
    89
    25
    Cornwall
    yes they do flash on main beam which is the odd thing about this. They just do not flash when the lights are off. Other Dethleffs A classes have the same fault it would appear.
    My concern is that whilst the van is only a year old it will need an MOT at some time and that concerns me in that this may be a failure.
  5. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    You are welcome to pop in when passing and I can have a look for you.:thumb:
  6. talaris
    Aug 17, 2012
    89
    25
    Cornwall
    Thanks. May well do but it is back at the dealer to fix at present.
  7. D magic
    D magic Read Only Funster
    Apr 25, 2011
    11
    Devon
    Flash or smash?
    Excuse the heading, it was my idea of humour, due to the fact I have had two new headlights in the last two Years, both have shattered. Is this maybe a design fault (nearside both times), a weakness through vibration or am I just really unlucky? Would be interested to hear from other owners
    As for the question about headlamp, I bought a new Dethleffs A Class two Years ago, and just as you say, the headlamp flash did not work. The relay clicked, but no light. I contacted my agent who contacted Dethleffs, and guess what, that is how it is meant to be, hmmm, was not impressed and I was not happy at all.:Angry: I got my dealer to get under the bonnet and rewire it so that now I do get a flash of sorts, albeit not main beam flash. So to sum up, apparently it is not a fault (yeah right).
    Hope this helps:thumb:
    Regards
    Chris
  8. talaris
    Aug 17, 2012
    89
    25
    Cornwall
    Hi Chris. Seems that we use the same dealer in Torbay as we are from the same area. Same problem and yes mine has had a new near side light too although it was fitted just before we bought it. Ours is just a year old.
    Interesting about the flash as if he same dealer they can do the same for me.. Any idea what they did?
    Do you like the Dethleffs - we do but had a few issues which Kerrs are slowly sorting.
    Regards
  9. D magic
    Apr 25, 2011
    11
    Devon
    Opinion
    To be fair, I like the Dethleffs motorhome, it ticks all the boxes for me and performs well. That said, we have had a couple of problems which Kerrs leisure have sorted out, all be it over a period of time, the girl on reception, Natalie, is only young but a fully qualified technician. She is very helpful, knows her stuff and offers great after sales support and advice, a name to remember when you phone with a problem.
    The light business is a bit of a pain, I believe Mike the techy changed my wiring so I had a flash, but I don't think it is a main beam flash, just a main light flash, better than nothing. I always drive with sides on anyway.
    Would be interested to hear if you have a problem with your light cluster, as I said earlier, I am about to order another set, just under £500 from Ireland. Much cheaper than Kerrs Leisure.
    Chris
  10. talaris
    Aug 17, 2012
    89
    25
    Cornwall
    Hi Chris.. sent you a pm but not sure if you got as nothing in my sent items so copied below.
    Hi Chris
    We like ours too although not without problems initially. I was just a year old but was badly pdi'd,
    broken awning, hater issues, radio not working, headlights, wrong manual and service history, loose dash, new habitation battery fitted by them was 65ah (!!!) and some more. Natalie was not hugely helpful and when I called the day after we collected she said they were busy and would look at it in a months time. Did not go down hugely well.
    They are on their way to rectifying everything but is has been back with them 5 times for a total of 5 weeks now. Picked up twice and taken back the day after twice. I am picky admittedly but spending that sort of money was not an unreasonable ask in my opinion to have everything sorted quickly. Russell is quite good, he's the new service manager I think.
    Apropos the headlamp we had a new fitted by them, n/s I believe as it had a crack but not sure hoe it got like that. I assumed a stone or something. will keep an eye on it though so thanks for the heads up.
    Where are you and do you use it locally? We do, Brixham and North Devon are favourites but we are new to this, being our first mh.
    Regards
    Tony
