Dethleffs 7014 - Awning Light - 2007 (1 Viewer)
jtp890
591
393
wakefield
Dethleffs 7014
13 years on n off
Anyone had any experience of removal / bulb change.
Fixing surround removed ok, but glass cover is firm to body?
Jul 12, 2013
3,869
5,262
The City of Henlow
Adria Supreme
Since 1980
I do not know the fitting for your van but on mine, I replaced the light (LED) from the inside of a cupboard.
steviebouy
120
110
Pucklechurch, Bristol BS16 9SE, UK
Low Profile
Since July 2011!
If you have the same unit as on my Dethleffs you will find inside the cupboard a black plastic cover held by a few small screws. Once this is of you can see the rear of the light unit where an obvious cover clips off revealing the bulb. Don't remember mine being LED but would probably be a good idea to substitute one. The make of the lamp is Jokon in case you wish to try a Google.
Steve
Jul 12, 2013
3,869
5,262
The City of Henlow
Adria Supreme
Since 1980
Ere, rosalan, I didn't spot that the OP posted 6 months ago either!
I did notice Steviebouy but thought someone else may find the same problem. I noticed also that he did not come back with an answer, so assume it is still dark outside at night.
steviebouy
120
110
Low Profile
Since July 2011!
Yes, OK, fair point! I do tend to go back through older posts for solutions if I can. Also would be good practice to confirm if suggestions have been helpful or to post how a problem has been solved.
