delamination of roof liner (1 Viewer)
T
treflynman
Hi,
The pimply surface on the outside roof of our motorhome (741) is coming away from whatever it was stuck to. This is the surface which you can climb onto and sit or stand on. We haven't done that but it is 6 years old and spends all its time outside.
Anybody any experience of this?
dylan
4,110
566
sw wales
none
n/a
Welcome to the FUN site, alot of the funsters are at the new years meet but I am sure someone somewhere here will have an answer for you soon. :thumb: ::bigsmile:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Hi,
You mean like a mat ?
I know tarmac surfaces get water underneath then when the sun shines the water boils off and blows bubbles even in thick tarmac.
I'd be thinking of cutting a X open it up, let it dry and bond it back down.
Unless it looks worse than a simple fix.
Anyway, not something you can do for a good while yet.
Brian.
williamb
42
14
Lancashire
a class
if it is a rapido motorhome you are talking about i dont think the pimply surface on the roof is stuck to anything if you wash the roof with hot water you can see the roof expand it is very flexable i just think this is normal.:Eeek:
Sundowners
3,289
3,571
Suffolk/Central Portugal
37 years
If it's a "rubber" roof you should be carefull what you do with it/put on it, the rubber is not too happy with any petroleom products.
Nigel
43,295
49,274
Hi treflynman,
i wouldnt worry about it..........
the roof on my kontiki is just the same.
it is just a fiberglass/abs skin laid over the roof panels and sealed at the edges/wall joints, pretty much like the rear panel.
it's a different construction to the wall panels hence you can walk on it.
providing there are no leaks around skylights/vents/edges ect it is normal and nothing needs doing.
Terry
11,926
9,033
Lincolnshire
Can't remember ;)
Hi treflynman,got any pics of the offending bits ? It could be a simple added bit (say non slip matting for walking on)or something more sinister,do not have a a rapido so without seeing it,it is hard to give proper advise :thumb:
terry
T
treflynman
When I work out how to attach a pic I'll send one in tho the problem is only noticeable when you touch the surface.
searider
8
north lincolnshire
low profile,
3 years
roof liner
hi, treflynman, Our 746 roof is the same, it was like it from new,
now 10 mths old, possibly deliberate to reduce stress cracks,
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
rapido 741 roof
:Cool::bigsmile:ont worry too much about the roof on your 741 I have had the same model and it was just the same if it doesnt leak dont mess with it . and as an aside I have just seen my old van on a dealers website at £8995.00 more than I traded it in for wow.
7
7735
spongy
Hi,
The roof is'nt stuck down on rapidos, it allows the roof to expand and contract.Its nothing to worry about.
