Delaminated window (1 Viewer)
Aug 27, 2014
1,910
3,732
Shropshire
McLouis Tandy 640+
Since 2014
I've a window on the van that has become delaminated, in other words the inner and outer acrylic panes have separated. It's a PolyPlastic brand window - lots of stuff online about this.
It's only a small window, on one of the kids bunks at the back of the van, high up. EECO have given me a quote of £85 + Vat to rebond it, and I've got to pay the carriage there, so it's looking like that option will cost around £120, which seems a bit steep for what it is.
So, looking at gluing it myself. Anyone done this and can offer any tips? Only one I've seen online was someone who used Bostik, more because they had it around already than because it was selected as the best adhesive!
A risk of course is moisture being trapped between the panes, I'll have to be careful what day I choose to do the job.
FJmike
972
1,046
Swindon
over ten years
Not any experience of glueing but have you tried your local caravan medic?
TheBig1
17,509
42,755
the special acrylic glue which is used bu specialists sets clear using a uv lamp. pretty expensive stuff even if you have the right equipment and a clean dust free area to work in. £120 is reasonable for a pro job with a guarantee
SandraL
1,373
985
Somerset
Hymer b694sl
I did a few years back on a caravan window. The finished job was solid but the glue was visible between the 2 panes. On that window there was " black dots" towards edge of window and it disguised the glue marks. Sorry cant remember make of glue. It was very thin and melted the window to form a weld.
Nov 4, 2011
5,887
38,112
Uk
Be careful about doing DIY job because I believe EECO won't repair a window that's been glued before.
Nov 5, 2013
3,065
96,616
Shropshire
Carthago chic e-line
Since 2013
Did anyone come up with a solution? @Feltwell , one of ours has done exactly the same.Have emailed poly plastic in Holland but I won't hold my breath!
Nov 5, 2013
3,065
96,616
Shropshire
Since 2013
At least they replied,obviously sensitive information! :(
'Unfortunately we cannot give any information about this situation, we only produce the windows. I would like to recommend you to contact your dealer'
Simon Richardson
212
139
East bound & down.
Carthago C Tourer 150 I
Full timing since Dec 2017
I had the same from them a few years ago when we had a Bailey Caravan.
Traded it in in the end - Pile of shite. And I bought it brand new.
Apoxy Resin sticks anything pretty much.
Nov 5, 2013
3,065
96,616
Shropshire
Since 2013
Got some acrylic weld cement of the internet,removed window,put a bead of adhesive between the two sheets,put a small batten either side,left clamped up for 24hrs and replaced window...so far so good!
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
Used Stickall with success(y)
