Dead trailer socket
Discussion in 'Tech/Mech General' started by Mikeco, Nov 12, 2014.
  1. Mikeco
    Mikeco Funster
    Sep 26, 2013
    774
    582
    Market Rasen
    Set off from Dover this morning and the trailer lights were working, arrived at Tours and nothing is working. Any ideas why nothing is working. Travelling down to St Jean De Luz tomorrow so what's Franch for " They were working when I set off Officer ".
    Mike
  2. Badknee
    Badknee Funster
    Aug 25, 2014
    3,840
    17,258
    notloB
    Humph, the only common denominator is the earth wire, all the bulbs need it.
  3. Mikeco
    Mikeco Funster
    Sep 26, 2013
    774
    582
    Market Rasen
    Thanks, I've just looked at the wiring to the socket in particular the earth but it all looks okay.
    Mike
  4. Mattyjwr
    Mattyjwr Funster Life Member
    Aug 18, 2013
    1,938
    3,422
    Beds
    Is it fused?
  5. Badknee
    Badknee Funster
    Aug 25, 2014
    3,840
    17,258
    notloB
    A tester would help. The earth is the white wire.
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,632
    3,465
    Telford, Shropshire
    Assuming your motorhome is based on Fiat/Peugeot/Citroen X250 it will almost certainly have a towing relay box in the wiring, this will have a single power feed direct from the vehicle engine battery via a fuse, possibly in the engine battery compartment (under passengers cab floor assuming RHD). This feed is the second common item to towing wiring.
    D.
  7. Mikeco
    Mikeco Funster
    Sep 26, 2013
    774
    582
    Market Rasen
    Just had another look and both indicators are working but not the
    Thanks for the reply, it's a 2012 Boxer and the tow bar was fitted by the dealer. I will have a look at the fuses to see if one has gone.
    Mike
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,265
    17,931
    YO11 2BD
    I agree with Dave
    multi/7 way canbus bypass relay fault or relay feed fuse blown.
  9. Mikeco
    Mikeco Funster
    Sep 26, 2013
    774
    582
    Market Rasen
    Had another look and the indicators are working but not the tail and brake lights, would this still be the relay?
    It's a 13 pin socket.
    Mike
  10. fifer37
    fifer37 Read Only Funster
    Apr 30, 2011
    8
    FIFE
    Had the same problem with my Compass Avantgarde 180. Relay was behind the nearside rear wheel exposed to all the elements. surely common sense would prevail, and site it, inside,away from the elements.
  11. pappajohn
    Aug 26, 2007
    30,265
    17,931
    YO11 2BD
    Could still be the relay but unlikely.
    the relay has one common feed wire from a 12v source feeding all 7 relays.
    each light should have its own bypass relay...2 x tail...2 x stop...2 x indicators and the 7th ..rear fog light.
    the chances of 4 relays failing at once are pretty slim unless the box has filled with water.
    13 pin socket still uses 7 pins for lighting and 1 or more pins for earths.
    any others are for split charge and fridge for caravans etc.
  12. sdc77
    sdc77 Funster
    Jan 28, 2013
    2,759
    3,270
    East london
    Exactly what happened to mine.. In my case the cable had rubbed.. Needed the new Canbus friendly relay fitting and wiring replacing.. My relay was beside the battery
