Dashboard Cameras (1 Viewer)
Biggles
151
33
Essex
Autotrail
Since 2009
My last and fairly basic dashboard camera has died so with that in mind what is currently out there?
Links to experience and wishlist
Dec 6, 2011
11,587
25,403
South Wales
Coach built Adria
i have one of these, not expensive and the play back via pc shows video, speed G forces, multi map tracking of route. good clear picture / resolution:thumb:
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
A link to where you can obtain one would be good.::bigsmile:
Roryboys Dad
631
805
Glapwell Derbyshire
Pilote Reference P716 LPR
Before you make your mind up which to buy have a look at all the Cameras reviewed by Techmoan - www.techmoan.com
I bought a DR 32 Driving Recorder after seeing his review of the camera and it is easy to set up and use.
There are cheap cameras and expensive cameras that work perfectly well - just buy one that suits the amount you want to spend.
:france::france::france:
GJH
29,450
38,827
None, now sold
2006 to 2022
I just bought Broken Link Removed for the van.
I bought one similar last year which I now have in the car.
They work OK for what I need - and they will mount either way up so don't have to be mounted at the top of the windscreen with cables routed under lining &c.
Oct 2, 2012
149
169
Shoreham by sea
c class
I'm a newbie
Iv got the same one as GJH got it last year good as gold does what it says on the box easy to set up Gary
Aug 29, 2012
126
109
North Suffolk
Panel van conversion
since 2011
I have bought two of these, one for the motorhome and one for the car, saves having to swap about. They may be a lot cheaper than some but they do work well.:thumb:
golly
2,005
69,615
Land of the Prince Bishops
HYMERCAR PVC
since August 2009
Yes I got one of these
had a very cheap one before this, which worked fine in daylight but was cr*p in evening. This one is much better in low light. May not be as good as the expensive ones but its good enough for me
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
These are getting cheaper all the time.
I have one the same as GJH above in my car (now only £35 but more when I bought mine) and it's good and has GPS and speed logging, however its picture quality is not brilliant.
I have a very basic one in the MH which failed to record the reg no of the lorry which smashed my mirror (£1,000 to replace) due to poor image quality, so am looking to replace it.
Biggles
Biggles
151
33
Essex
Autotrail
Since 2009
Can you post a link?
JohnH
404
993
Southport
Just looking
I noted that Graham had said his camera could be fitted either way up. Do any others have this feature. I would much prefer a camera to be fitted at the bottom of the screen than the top which has a strip across the full width.
GJH
29,450
38,827
None, now sold
2006 to 2022
The camera I have is the only one I found that will mount both ways up, basically because it clips into a holder.
For the car I use a "bean bag" with a Camera Flash Hot Shoe Mount stuck on with Sikaflex. The GPS receiver is riveted to the front of the bean bag base.
In the van I stuck a plastic circle, obtained with a Garmin sat nav, to the dash tray using Blue Tac. The suction mount sticks to that.
