Damp
Discussion in 'Tech/Mech General' started by wizzer59, Jul 7, 2014.
  1. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,954
    2,749
    Englishman in Mid Wales
    Next daft question on damp, when using a meter what is acceptable or not if you get my drift?
  2. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,804
    1,027
    Cark, Cumbria
    Very difficult to give a hard & fast figure as I've found different vans give different readings due to different constructions. With the DT128 I find anything below 20 is generaly OK but the best way is to check lots of different areas till you get an Idea for that van. Also don't panic if you suddenly get a high reading, remember you are basically measuring the conductivity of the material so a hidden cable or metal bracket etc. could be the cause. If you do find damp the reading should get get progressively higher or lower as you get nearer or further away from the source. It takes practice but if you go over your van regularly you'll get to know its "normal" readings..
    • Like Like x 1
  3. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,954
    2,749
    Thanks Jay that makes perfect sense to me, I'm guessing that the reading is a percentage yes?
  4. DP_JAY
    Mar 17, 2010
    1,804
    1,027
    Cark, Cumbria
    Doesn't actually say percentage but as the scale is 0 -100 I presume so.
    For guidance the instructions state Gypsum board reading of 35 or less is dry as is cement with a reading of 25 or less.
    • Like Like x 1
  5. hilldweller
    Dec 5, 2008
    27,204
    26,192
    Macclesfield
    Get a piece of wood, dry it in the oven, measure. Damp it one side, meaure both sides. Soak it measure. Get the feel of the tool.
    • Like Like x 2
