damp
Discussion in 'The Beginner' started by jgee, Nov 20, 2012.
  1. jgee
    jgee Read Only Funster
    Dec 21, 2009
    85
    wigan
    just had habitation check done on avangarte compass 3years old found bad damp in corners of overhead cab .habitation check done independent and returned to asses at dealers anyone experience this what time span would it be fixed in and any future problems
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,421
    5,449
    East Sussex 01-580-881288
    Without seeing it, could be just condensation causing it, due to lack of enough insulation.
    Maybe a good drying out and increased insulation?
    Peter
  3. Vlad The Impaler
    Vlad The Impaler Funster
    Apr 22, 2012
    1,623
    2,192
    Rutland
    Some people seem to think condensation build up is down to poor insulation however this is not always true.Someone on this forum I can't remember who hit the nail on the the head when I experienced condensation build ups on windows and roof on over cab bed,some mornings wet bedding and droplets on roof.Its caused by warm moist air hitting a colder surface,the solution..............Circulation ..........it wasn't poor insulation as when I had my problems it was summer! 4 bodies and a dog in van.
    Anyway the way I solved this was ,to use the fan on the blown air heater (even when no heat required) since then no condensation even recently when cold.
    I've recently moved house and it has double thickness insulation in loft,cavity wall insulation and double glazed windows.The previous owner was an elderly lady who obviously didn't like being cold!
    However condensation worst than anything I've seen,at this time of year every window in house is covered in it .In her quest to keep warm she filled in every air brick SO NO CIRCULATION! Plenty of insulation but no Circulation.
    Air movement is the key!How many cars and busses do you see at this time of year all steamed up, not due to damp but down to poor air circulating round vehicle
    Regards Vlad
    • Like it Like it x 1
  4. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    very valid point you need a flow of air
  5. ubuntu1
    ubuntu1 Read Only Funster
    Feb 13, 2008
    155
    44
    Derbyshire
    Don't panic a good repair (if it is damp) will leave the van looking like new and the seals will probably be better than when the van left the factory.
  6. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    Correct.....I have said many times on this forum you must have air circulation...:thumb:.................unless you have a leak and you know water is getting in ...that is different
