damp readings
Discussion in 'Motorhome Chat' started by camocam1, Sep 24, 2013.
  1. camocam1
    camocam1 Read Only Funster
    Aug 28, 2012
    1,112
    783
    Elgin,Moray,Scotland
    bought myself a damp meter which goes up to 20% checked everywhere I can and all ok (10-12%) EXCEPT above both wheel arches one on drivers side reading 20% the one on the passengers side where the external lockers are is going off the scale !!!
    Only along the very bottom at both sides 2" up the walls readings 12%
    I suspect the ingress must be coming from underneath somewhere in the wheel arches, any ideas where to look ??
    Plan at the moment is to open windows and put on small heater to try and dry out the walls.
    Any thoughts comments would be most welcome
    thanks
    Ron
  2. motorhomelover
    motorhomelover Banned
    Jul 28, 2010
    1,719
    613
    The world
    A little knowledge is dangerous so take the van to a qualified repairer to seek profession advice
    Once damp is in. It's degrading the structure and no amount of heat will resolve the situation
    :cry:
  3. camocam1
    Aug 28, 2012
    1,112
    783
    very true a little knowledge is a dangerous thing but unfortunately the only dealer with 65 miles is the caravan dealer I bought it from 15 months ago who said they had done a damp test and all was fine.
  4. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    Out of curiosity is your van either a 2005 to 2007 or a 2009 ?
    All well known for rotting floors :Eeek::Smile:
    Terry
  5. camocam1
    Aug 28, 2012
    1,112
    783
    Terry I believe that is the case, mine is a 2007 but floor underneath is sound (except 2 small areas at the back corners) been underneath and poked about with a screwdriver and all sound even in the areas round about the wheel arches (do that every month or so) damp readings are in the wall area just above the floor in the lockers, no damp reading in the floor area which is also a puzzle
  6. rolandrat
    rolandrat
    Jan 5, 2013
    436
    257
    Lancashire
    Is it possible to remove the side skirts and rear wheels to access the damp area? It could be that some sealant is missing and needs drying out under cover. If it is left untreated you could end up with floor delamination. At least you are now aware of it and can do something about it. Good Luck.
  7. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,174
    14,065
    Heavan
    if you could upload a couple of photos that would be useful.
    I have had damp in my locker where the wheel arch was not sealed properly. Thank fully, I got to it nice and early and carried out a repair and resealed. All is well now, I have had a little issue in one of the back corners which also seemed a mystery as to where it was coming from. Again a repair, resealing in various possibilities of ingress and all is now fine.
    I use my damp meter all the time, there are some gotcha's though, if your close to wiring, I understand that this can increase a reading, (don't know why).
    As for a little bit of Knowledge being a bad thing and take it to a dealer. Sadly in my experience, the one thing that many dealers actually lack is a bit of knowledge. Far better to learn and gain the experience to do it yourself to keep your wagon on the road. Every van I have ever had has led me to find a little ingress at some point, mainly on the lockers.
    I have plenty of areas on my van that when I've looked at it, thought " looks rotten that sealent" and just added a bit more sealant to sort it out.
    10 years of experience has given me plenty enough to keep the beast on the road, I don;t want to buy another, I love this one too much, therefore a Damp meter and learning how to use it has been invaluable. :thumb:
    • Like it Like it x 2
  8. camocam1
    Aug 28, 2012
    1,112
    783
    yes side skirts can de easily removed and resealed (I think just screwed on) Not sure how I would jack up and support a 3500 tonne MH safely as I have NO jacks etc, But I take your point that may have to be done, just hoping to get it dried out at the moment to stop it getting any worse till I can get it fixed as we are booked up to be away every weekend until the end of November now.
  9. Terry
    Terry Funster
    Dec 27, 2007
    10,784
    6,293
    South yorks
    They put the blame on failing to seal the skirts to van sides and instruction was given for dealer's to check and reseal where needed :Smile: Not sure what damp meter you have but about 15 % reading is susposed to be o.k.
    Best to check all seals on your van including seals around locker doors :thumb: Easy to mask up and stick new sealent on probably make a neater job than the original :BigGrin:
    I don't trust the rubber bubble seals around the window's so I mask up and seal all of them. Only takes an hour or so to do the whole van :thumb:
    Terry
  10. camocam1
    Aug 28, 2012
    1,112
    783
    hagnap what photos would help as there is nothing to be seen inside the lockers as all looks okay just getting high moisture readings but NO obvious signs of damp to be seen.
  11. camocam1
    Aug 28, 2012
    1,112
    783
    Terry thanks for your comments the meter is a protometer one that cost about £50 so maybe not the best but not a lidle or aldi special.
  12. chaser
    chaser Funster
    Feb 16, 2013
    7,944
    9,006
    uttoxeter
    Don't know anything about damp walls but being as it above the wheel arches isn't it just soaking up spray off your wheels:Wink:
  13. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    Damp can appear very quickly. All the readings taken when we had the habitation check done in January were fine but then Dave Newell spotted a small area of damp in the locker floor (rear offside corner) when fitting a rear view camera a few weeks ago.
    The van is currently at Teesside Caravans being repaired. Lucky Dave spotted it before it became more serious.
  14. haganap
    Dec 5, 2007
    11,174
    14,065
    Heavan
    I was thinking of the proximity of the locker to where your high readings are?
    can you take a reading from the inside of the van or are you forced to take it from the outside?
    You said, readings are just above the floor, in the locker? sounds like a classic case of locker not sealing properly and or seal on the outside breaking down.
    Water sits at the bottom, gradually climbing and damp...
    easy fix, done mine not so long ago. :Wink:
  15. camocam1
    Aug 28, 2012
    1,112
    783
    hagnap
    readings have been taken from inside the van under the lounge seats. as I said NO obvious sign of damp but will see what I can do re photos.
    chaser
    that's what I think but would not think that it should be able to penetrate the van to cause damp as surely should be sealed.
    looks like a reseal job on the side skirts and locker which was on my to do list BUT how do I dry it out meantime ?? Can I dry it out ??
  16. hilldweller
    Dec 5, 2008
    27,713
    26,809
    Macclesfield
    Not a hope in hell.
    Rip open the wet patches dig out any soft wood then blow warm air in for anything up to a month.
    Then work out how to repair it. If it's not load bearing, don't panic, you can do it.
    And of course, find the leaks.
    • Like it Like it x 1
  17. haganap
    Dec 5, 2007
    11,174
    14,065
    Heavan
    Brian's quite right TBH. Ive used two ways and both have been successful dependent on the requirements.
    First is, don't panic!! you would be amazed at how many vans have a little bit here and there.
    I have had a sittuation where I have had to dig/cut out the old rotted wood and then replace with new board when reaching the dry bits, simple but bloody messy beyond belief.
    I have also drilled several holes around the damp area and inside the damp area. I have used ronseal rot stop and injected it in to the wood and allowed it to dry out over time. The main thing to do is to make sure it does'nt continue to leak. Find the ingress, and cure it. If it is the locker, on my first I added some additional rubber seal to it that I purchased off ebay. Worked a treat.:thumb:
  18. camocam1
    Aug 28, 2012
    1,112
    783
    Don't mind having a go at resealing but don't fancy riping anything out
    What about putting in a dehumidifier ??
  19. hilldweller
    Dec 5, 2008
    27,713
    26,809
    Macclesfield
    You aren't listening.
    I dug out soft wood and it still took a month with a fan blowing on it to dry the good wood ready to rebuild it.
    Sounds like you are lucky, it's hidden so it does not matter if it's not cosmetically perfect.
    OK - get out a thin screwdriver ( or a big BBQ skewer ) and see how far you can push it in, don't go right through though.
  20. haganap
    Dec 5, 2007
    11,174
    14,065
    Heavan
    you can use a dehumidifier but Im sure I read somewhere it's useless in this situattion, and of course the problem will still be there. Also depends on how rotten the wood is. If it's really bad drying it out will just turn it paper like and very brittle.
Similar Threads
  1. Chezer and Chezer
    14
    675
  2. Ains-campers
    11
    515
  3. apm101
    20
    1,085
  4. Revolvor
    8
    638
  5. Petest
    11
    1,179
