Damp Problems!!!! (1 Viewer)
gazzeroo
63
5
Norwich
I`m a newbie
Hi guys, once again looking for advice. I have just run a damp meter round my 20 year old MH. It`s in pretty good nick apart from a couple of places. The meter indicated 15/16% around the bottom left corner of the van in the wc. Also around the fan in the roof near the kitchen, but only on the rear edge. I have looked outside and can see where it is possibly letting in water. My question is, do I seal up the suspect areas now or wait til the meter level drops. The van stands outside all the time, but with the summer approaching, it might have a chance of drying out more. I don`t want to seal in the damp. Also any advise on what to seal it with, I have good quality silicone and Soudal classic. As always I would really appreciate your comments
regards
Gary
GJH
29,450
38,827
None, now sold
2006 to 2022
There were some minor spots of damp found in our van when it had its habitation service 15 months ago. We had it re-sealed ASAP afterwards and the problem was cured by it drying out over the summer.
MikeD
3,936
3,697
London
IH PVC
Since 2012
Our three year old Autotrail regularly had 12 -18% damp readings but was passed on its annual Hab check. This year 40% and a warranty claim. Booked in for May. Hopefully then ok
Sep 3, 2012
7,552
26,057
Cheshire
C Class Elddis 175
8+ years
I would seal the areas you think need it with a good sealant and check again when the better weather comes along next week -i thought that 15% was ok -especially for a toilet area
May 7, 2013
845
1,353
RUK
On our 2nd MH now a AutoTrail Savannah which we're absolutely delighted with
On my Protimeter up to 15% is considered "dry". In my opinion you must recognise that given you're measuring the dampness on the inside and only on the surface( if a "prong" type meter is being used) you must assume that if the surface reading is that high behind the point tested may be higher and more worrying. I now have bought one of the so called "contact less" meters and they do measure up to 40mm deep and give more useful readings
gazzeroo
gazzeroo
63
5
Norwich
I`m a newbie
Thanks chaps, for the replies, helpful as always. I will probably seal the affected areas and keep an eye on them
Reactions: f6c
AlunJ
3
Stockport
C class hi top
Since 2010
Hi any recommended examples of the contact less meters, and what % should raise concerns??
May 7, 2013
845
1,353
RUK
TFA Dostmann HumidCheck Contact 30.5503 Material Moisture Measuring Device
available on Amazon where I bought one for £59. Be careful I've seen the same one on sale for up to £80.
Up to 15% is considered "dry" 15 to 22% considered requiring further checking 23% upward normally considered "wet"
Expect immediately around window seals to be high as condensation always forms on the materials used to form the window opening . This is absolutely normal and of no real concern as long as it does not extend away from window opening at all
Hope that assists you
Ian
Sep 5, 2012
2,109
42,216
Scotland
East Neuk Fifer
since 2012
Hab check done a couple of months ago and damp free but I bought a non invasive metre that was recommended here. We've been away for a few days came back Wednesday, went over areas with metre today and a couple of areas over 20%, the kitchen window frame area and just under roof and high wall area in lounge. It doesn't look or feel damp. East Lothian-20150417-00740.jpgcould it be condensation build up.
