Damp meters are they any good (1 Viewer)
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
Just posted this in another thread, but thought its worth one of its own, in case it's missed.
Got the damp meter out yesterday, nearly had palpitations, shoved the probes under the rubber on the windows, every one went off the scale, so got the rubber off one , dry as a bone! So shoved the probes just in the rubber, off the scale, has anyone else found that the rubber reads soaking even though it's dry, never come across anyone saying that before, could have you ripping your van to bits for nothing
movan
21,492
120,753
Moving around
Burstner
since07
Don't know about rubber, Chaser, but similar thing happened in my house. Ended up paying for a wall to be knocked down and rebuilt to be told the problem was from next door... :( ... Damp!!! The mere word gives me goosebumps. Hope you get rubber sorted.
chaser
Feb 16, 2013
19,734
52,021
uttoxeter
50 years
Perfectly dry rubber what else does it show wet when it isn't?
Apr 19, 2014
92
43
CHESHIRE
A CLASS
1 YEAR
I use a dehumidifier from ALDI, run it for 3/4 hours at night on a timer , off the solar panel thru the inverter so costs me nothing and keeps the van nice and dry
Woooody
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
If dry rubber is reading high moisture then the rubber is conducting electricity, this is how these meters work. Rubber is a natural insulator so if it is conducting electricity then there is either some sort of additive in there or perhaps something on the surface like an adhesive. However, my guess would be the rubber is dry on the surface but has moisture inside it.
tambo
874
639
Dunfermline fife scotland
a class
MH Since 2008, ex tugger and vw campers since 1992
Yes but nothing is wet, it just says it is
Maybe it was your undergarments when it went off the scale :p
Have to say I've a cheap one from ebay which seems to work okay it showed a 7% reading on my rear window and when I removed them all today to reseal there was signs of a leak in that window and the one above cooker .....my windows don't have those rubbers though it's the ones in frames
Luckily there wasn't any damage and I've caught them in the nick of time :)
scotjimland
2,324
10,045
A Woosh bang
The rubber the window seal is made from probably has carbon black added (an excellent conductor) to make it UV stable.. hence the conductivity .. try your meter on a dry van tyre.. I bet it shows it's 'wet' ..
don't press too hard.... :LOL:
chaser
Feb 16, 2013
19,734
52,021
uttoxeter
50 years
Yeah you are right , but it doesn't show as much as the window rubber
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
a moisture meter is an electrical resistance meter nothing more, should be used for comparative readings of identical materials. Differences in readings at various places will show up a damp problem (note DIFFERANCES).
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
Always worth doing a battery check on the damp meter as well before use. Duff battery = weird readings, a bit like a multimeter.
Puddleduck
12,385
43,990
Scottish Borders
Without at present
On and off for many years.
A good working damp meter is worth it's weight in gold when used correctly.
Puddleduck
12,385
43,990
Scottish Borders
Without at present
As ScotJimLad said there will be an additive in the rubber which is an electrical conductor. Carbon black used to be used quite a bit in specialist paints. I'm not sure if it still is as it's over 30 years since I worked in the paint industry.
What did the damp meter show elsewhere? Normal readings?
chaser
Feb 16, 2013
19,734
52,021
uttoxeter
50 years
Yes as I said in an earlier post I checked the wall under the window and it showed damp off the scale but the probes were touching the rubber didn't realise till I moved the rubber and checked underneath , dry as a bone , dry everywhere
tambo
874
639
a class
That's quite rare for a compass :p
chaser
Feb 16, 2013
19,734
52,021
uttoxeter
50 years
Is that right, can't see anywhere where damp can get in , no joints on roof apart from roof light and all the windows seem well sealed, only tried it because I heard same as you, but not even condensation or round sinks , nowhere
