damp meter (1 Viewer)
Jul 8, 2008
1,137
1,467
Weymouth, Dorset, UK
c build
6 yr
hi has any one got one of these
if so what do you recond
thx dave
hope pic come out
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Yes, we got one to replace our old one which deceased!! £7.50, reduced at Aldi!
The unit seems reliable so far, giving expected readings.
The only downside is there is no 'hold' function for the display. This makes it difficult to read in tight corners.
paulmold
892
302
North Wales
7 year (25yrs a tugger)
I got the same one from Aldi (full price). It matched the dealers readings, so seems good value.
Feb 16, 2013
19,732
52,015
uttoxeter
ambulance conversion
50 years
Got one of these, but can't fathom out which scale you are supposed to be useing, the thingy goes up the middle so is the reading say. 20 or .9 for example, goes up to 44 on one side and to2.0 on the other could be either:Sad:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
All these cheapo meters are just a guide. If one area of you MH is low and another is high then start looking carefully.
Pick a place where water is unlikely to get to, there's a base reading. Then go hunting.
Feb 16, 2013
19,732
52,015
uttoxeter
50 years
Should be it if I have done it right:Doh: no it's not try again
Feb 16, 2013
19,732
52,015
uttoxeter
50 years
Think this it
Feb 16, 2013
19,732
52,015
uttoxeter
50 years
If you stick it in something that's only 2 how do you know it's not 40
2bob
Jul 8, 2008
1,137
1,467
c build
6 yr
aldi £4
left hand side if im right //wet your finger and stick the meter on it
done my m/h to day hardly move off the bottom scale
Oct 2, 2012
149
169
Shoreham by sea
c class
I'm a newbie
Hi if Im not mistaken the left hand side is for wood and the right is for materials etc I work from the right hand side if its reading 04 /06 dont worry ( right side) its a moisture meter very sensitive if it goes off the top then see if you can see why if you want to hold the reading hold finger on the set button hope this helps but dont forget its very sensitive put it on a dry hand and it will go to the top
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Here's the one I have, recommended by a friend who uses his everyday and swears by it.
I find that there is no need to force the pins in (there's 4) and the hold function is excellent in the dark, awkward areas.
Not too expensive either.
Link Removed
Regards,
Trikeman. :winky:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
READ THE BLOODY INSTRUCTIONS!!!!!!!!!
Remove the cap to expose the pins. Stick pins in wood!
Left hand scale for wood, right hand scale for plaster!
The contacts on the cap are for checking calibration, again read the instructions!!!!!!::bigsmile:
Feb 16, 2013
19,732
52,015
uttoxeter
50 years
I've read em ta, but how do you know which it's showing if it's very dry wood it could be the right one but if it's soaking plaster it could be the other side, how do you know
Feb 16, 2013
19,732
52,015
uttoxeter
50 years
How does it know what you are sticking it in:Eeek:
