Damp Meter - Has any one tried these
Discussion in 'Motorhome Chat' started by 2bob, Nov 13, 2014.
  1. 2bob
    2bob Funster
    Jul 8, 2008
    617
    337
    dorset
  2. rangitira
    rangitira Funster
    Jun 30, 2010
    6,475
    13,562
    Cornwall
    They had a similar thing in ALDI couple or three weeks ago
  3. 2bob
    2bob Funster
    Jul 8, 2008
    617
    337
    dorset
  4. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    • Like it Like it x 3
  5. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    I bought one of these (eBay item 271480282965) a few weeks ago. Took a while to come from China but seems to work OK and doesn't leave holes.
    • Like it Like it x 1
  6. Moodybrook
    Moodybrook Funster
    Jul 7, 2013
    800
    651
    Wet and cold place outside of M25
    Graham, I copied your example off another thread and have one on order, about how long did yours take ?
    Those prongs look ferocious !! :Eeek:
  7. GJH
    Aug 20, 2007
    27,349
    34,949
    Looking at eBay records I ordered it on 29 September and it was due to arrive between 8th & 20th October. eBay no longer gives actual dates for when feedback was left but I left feedback on the day of delivery and it was more than a month ago so it must have been closer to the 8th than the 20th.
  8. yodeli
    yodeli Funster Life Member
    Oct 12, 2008
    4,497
    8,608
    Balma (next to Toulouse) France
    Terry sent me one a few days before I went to Germany to buy my motorhome, and I must say that this little gadget works really well to see where it is damp or not!!
    I love it and keep it in the van to check each time I think about it. The one I have has a scale saying how damp it is . If it stays around 15 it's a bit damp but not desperate , mine is going from 2 to 13/14 in the wet places such as under the shutter in the kitchen or under the kitchen sink.
    Mind you I have as well a quite good sense of smell , and if there is any damp I can smell straight away . Unfortunately , this part of my body is not to be sold:D
    Frankie:cool:
    • Like it Like it x 2
  9. GAUDIE
    GAUDIE Read Only Funster
    Oct 4, 2010
    65
    8
    NORFOLK
    In my experience a moisture meter or damp meter is used to measure the surface moisture and cannot determine the amount of moisture within a material overall. Even the meters with probes can only measure the moisture at that point.
    If the moisture meter is being used to measure the dampness on the surface of a wall or ceiling of a motorhome and does record that dampness is present then the ingress of moisture to that point is likely to stem from the roof or outside wall and by the time it reaches the surface, where the reading is being taken the damage is most likely already done and a search will be needed to investigate the source ie the seals on the roof, windows etc.
    It is also possible that the moisture on the wall or ceiling may possibly be condensation rather than penetrative damp.
    Use the meters by all means but be aware of what the readings are indicating.
    I hope my views are useful and based on experience.
    Gaudie
  10. FIDGET
    FIDGET Funster
    May 7, 2011
    2,978
    6,152
    Isle of Wight
    What part !!!!
    • :Eeek:
    • :happy:
    My mind boggles
    I presume your nose
    • :whew:
  11. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,697
    10,393
    Norfolk and Toftir.
    My wife often tells me I smell when I'm damp. :(
    Edit: Here we go, another thread going off on a tangent. :doh:
  12. OllieUK
    OllieUK Read Only Funster
    Jun 23, 2013
    259
    297
    Ramsgate
  13. GJH
    Aug 20, 2007
    27,349
    34,949
    Certainly - and I agree that they are only an indicator.
    The engineer doing our habitation service last January found isolated high readings which he/we traced to cracked sealant and he was able to repair it pretty easily and cheaply. Without the check we would probably not have known until later, when repair would be more expensive.
    I bought my meter so that I could do spot checks from time to time in between habitation services, just to keep an eye on things.
  14. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,655
    7,908
  15. swanseajack13
    swanseajack13 Funster
    Aug 19, 2013
    483
    1,569
    Swansea
    rob clark one of use funsters needs more than a moisture meter a bucket would be better lol ray
  16. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,788
    12,913
    East Sussex
    Funnily enough there were pin prick holes all round the window - guess they must have known our van had a leak when it was new
  17. Robert Clark
    Jul 12, 2014
    6,788
    12,913
    East Sussex
    If you used a damp meter what would the reading tell you?
    We use our damp meter to test the water content of logs that we cut. Freshly cut trees can have a moisture content of 50%, and we season it until it's about 15%
    What reading would tell you your van is damp or dry?
  18. swanseajack13
    Aug 19, 2013
    483
    1,569
    Swansea
    the way you find out if you m/h is damp the dealer gives you free willies or arm bands or if very damp a life bouy fixed to the bike rackthen ask what prick made the marks around the window also hole filler on the office desk this is not wood worm send it back reject it you will not have the same look on it if you have it repaired show them the prick marks around the window lol ray
  19. schojac
    schojac Read Only Funster
    Apr 25, 2009
    339
    234
    Cambridgeshire
    Have had one of these types for many years now and regard it as an essential piece of kit. Yes it leaves 4 pin holes as I do go well into the board but try to locate test areas in places where the "damage" is minimal - behind curtains, upholstery etc. Roof light; don#t really care as I feel it a good trade off - damage against damp detection. No one to this day has ever commented on the tiny holes around the roof light.
    Readings; personally I take readings throughout the year and record the results. I then compare as some meters will give higher readings higher than others. It's the variation I scrutinise not the actual reading if you see my logic.
    At one location (lets keep with the roof light) I usually get the following at 4 points:
    Summer - 12%
    Winter - 18%
    This I feel is down to increased humidity and the colder climate. Anything above this would warrant further investigation.
  20. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,942
    3,930
    Corby, Northants
    I just rip all the internal panels off. No need for a meter. No panels left on inside of Motorhome now so dead easy to check !
