- Oct 8, 2014
- 1,639
- 3,027
- Autotrail Excel 600B
- Previous VW Camper + Caravan
I’d like some advice on a damp issue please.
Before I start, please don’t tell me I should have bought a German van!
I have just had my annual habitation check on my 8-year old MH. Rather than use the dealer where I bought it, as I did last year, they recommended a local mobile service this time.
Firstly, I was a bit concerned when he used a probe-pin meter, which I discovered later had left lots of small indentations in the panels. He highlighted an area of damp in one of the lockers. I’m not sure how he determined the actual values, as it just had a series of coloured LEDS, and he was moving it about so quickly, I could hardly note the readings.
The rather basic readings he reported were:
(15 under the window, 30/40 beside the locker door, 30 in the door, & 30 below the door.)
The MH is normally parked on a slight slope on my drive, so all the water from the roof drains down from two places on the off-side.
Link Removed
The locker with the damp is under the front drain point. I have noted in the past that the locker has two “close” positions, and needs to be clicked home to compress the rubber seals. If not fully home I did once see some water in the locker after heavy rain.
Their recommended solution is to remove and reseal the window over the locker, remove and replace an internal section 300mm x 300mm adjacent to the locker, and remove and replace the lining of the locker door.
To do this, they have quoted £1200. Are they having a laugh? (Not covered by insurance, as more than 7 years old)
If as I believe, the water was getting in through the locker door, will it dry out in time, without recourse to the drastic surgery?
I plan to fit some Fiamma Gutter strip to divert water away from the window and locker, and will always ensure the locker is fully closed.
Any comments? Thanks, John
Link Removed
