CVD results
Discussion in 'Motorhome Chat' started by sadlonelygit, Dec 10, 2014.
  1. sadlonelygit
    sadlonelygit Read Only Funster
    Jan 28, 2014
    155
    95
    forest of dean
    or old man MOT.
    passed with a couple of advisories (in VOSA parlance)
    Blood sugars at the top end of OK, ldl ok, hdl 5.9, BP 135/85 and RHR of 49.
    got the usual 'eat less crap and take more exercise' lecture and see you in 6 months:D
    • Like Like x 1
  2. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    CVD?
    http://en.wikipedia.org/wiki/Chemical_vapor_deposition
    Chemical vapor deposition (CVD) is a chemical process used to produce high-purity, high-performance solid materials. The process is often used in the semiconductor industry to produce thin films. In typical CVD, the wafer (substrate) is exposed to one or more volatile precursors, which react and/or decompose on the substrate surface to produce the desired deposit. Frequently, volatile by-products are also produced, which are removed by gas flow through the reaction chamber.
    Can anyone translate that to english!
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,953
    17,634
    YO11 2BD
    Abbreviations CVD
    Their Meanings
    canine distemper virus
  4. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,583
    5,672
    Yr Wyddgrug
    Cardiovascular disease perhaps?
  5. pappajohn
    Aug 26, 2007
    29,953
    17,634
    YO11 2BD
    Take your pick.
    CDV Canine Distemper Virus
    CDV Carte de Visite (small visiting card portraits)
    CDV Cell Delay Variation
    CDV Coverage Driven Verification (circuit design)
    CDV Criminal Domestic Violence
    CDV Car-Derived Van (UK descriptor for commercial vehicles)
    CDV Comcast Digital Voice
    CDV Committee Draft for Vote (International Electrotechnical Commission)
    CDV Compressed Digital Video
    CDV Comité Départemental de Voile (French: Departmental Committee of Sailing)
    CDV Cordova, AK, USA (Airport Code)
    CDV Core Democratic Value
    CDV Clutch Delay Valve
    CDV Check Digit Verification
    CDV Cooperative Distributed Vision (artificial intelligence)
    CDV Concours des Vins (French: Wine Competition)
    CDV Capacitor Discharge Vaporization
    CDV Comma Delimited Value
    CDV Central Drawings Vault
    CDV Concept Demonstration and Validation (usually seen as CD/V)
    CDV Credit/Debit Vendor
    CDV Conseil et Dépistage Volontaires du VIH (French: Voluntary Counseling and Testing for HIV)
    CDV Clean Diesel Vehicle
    CDV Carma Data Viewer
    CDV Cache Delayed Verification...
    Oppps.... wrong order CDV
    • Like Like x 2
  6. CWH
    CWH Funster Life Member
    Jan 29, 2014
    2,987
    12,537
    under a wand'rin' star
    whatever it stands for, it's a "pass" so that's got to be good... hasn't it?
    I mean - CVD is also Cold Vacuum Drying - been using your new Karcher, SLG?
  7. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,780
    11,989
    Plympton, Devon
    cardiovascular disease = CVD
    RHR had me thinking - then :doh: Resting Heart Rate.
    The figures look good to me except blood pressure a shade high. :)
    Dr DBK
    • Like Like x 2
  8. wingman
    wingman Funster
    Feb 10, 2013
    1,010
    2,548
    Romford, Essex
    Blood pressure readings made ezee....
    The upper figure is the systolic pressure. Put simply, it is the highest recorded pressure as the blood is pushed against the artery walls on heart beat.
    The lower figure is the diastolic pressure. This is the lowest recorded pressure as your heart rests between beats.
    Blood pressure is the combined result of Heart Rate, Cardiac Output and Stroke Volume.
    Of course your BP taken at the arm is not the exact pressure. It's just a convenient way of measuring a mean pressure without drilling into a main artery!
    A BP deemed 'normal' in one person, may not be so in others. As a very ROUGH guide, we used to use the fraction 100 + age / 60-80 (minus 10 systolic for a woman). Hence a 20 year old male at rest would have a BP of 120/70. A female of 30 years would be 120/70. Doesn't always work out, just a guide. Hence a resting BP of an 80 year old should not be 180/70!
    Best way to check your own pressure is to buy an electronic machine (a Sphygmomanometer) from outlets (like) Lloyds pharmacy, though there are other outlets. Make sure you do it at rest; not after fighting with an errant awning in the wind!
    Finally, if you've got two doctors, you've got a row! Assuming you're 60, with a BP of 135/70 one of them will draw air through his teeth and suggest you're at death's door, whilst the other will say you in excellent health!
  9. peter marshall
    peter marshall
    Mar 5, 2009
    2,702
    1,701
    Cleveleys,Lancashire
    When I had mine in September the sister said I was perfect, but she wouldn't put it in writing for me to show Lynn lol.
  10. kcy
    kcy Funster
    Nov 7, 2013
    722
    857
    east yorkshire
    Bp,aim for under 140/90
  11. trophychap
    trophychap Funster
    Dec 24, 2009
    722
    5,271
    bedworth warks
    The nurse took mine at the doc's last year, she looked a bit puzzled and then she said I will try your other arm I don't think the machine is working so I said same reading? yes she said 120/60 in both arms.
    I have always had a slow/low BP. I asked the Dr once what it meant he just said you will in all probability never die of a heart attack. Comforting though! Does that condemn me to a Long lingering death? LOL
  12. sedge
    sedge Funster
    Jul 7, 2009
    4,569
    4,087
    Nr Jct 3 M6
    A quick one can be arranged - if you would only tell me where the keys to the gun cabinet are!
    OTOH my DSN told me once if I wanted to murder someone, where best to inject the insulin to avoid detection! Odd really cos she's usually on your side rather than mine, it seems to me, whenever we've had 'animated discussions' in her office in the past ........
  13. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,084
    1,468
    Dover
    HDL 5.9 !!! that is really, really good. That is the one that clears the crap from the body to stop LDL/VLDL from blocking arteries
    • Like Like x 1
  14. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,151
    3,573
    walthamstow east london
  15. sadlonelygit
    Jan 28, 2014
    155
    95
    forest of dean
    our local surgery sends out the letter along with your 50th birthday cards.
    funny thing about it all is they take all your information, pump it into a computer and then ask did your parents have any heart problems (dad had a triple in his 70's and mum died from congestive heart failure) and regardless of your health and lifestyle, that's the indicator they pay most attention to! it doesn't matter that my dad smoked like a chimney, took no exercise, had a fry up every day and drank like a fish.
    i know we can't cheat death, but i'd rather not have an algorhythm telling me how long i've got left. a little too like logan's run for me.
    • Like Like x 1
