Cure for Dripping Frost Dump Valve (1 Viewer)
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
We have a Hobby 750 year 2000
fitted with a Trumatic C Boiler
The frost Dump valve is a separate unit.
The valve developed a drip leaking water constantly.
It's easily accessed. I took the valve apart a simple operation and inside it had a rubber washer very similar to those in a flush valve in a toilet tank at home.
The drip was caused by a build up of lime scale. I cleaned it out and the drip stopped.
however 6 months later it's started again. it could do with the washer replacing a simple job EXcept i can't find any stockists. Everyone wants to sell me a new dump valve at £82.
Does anyone know where we could locate a rubber washer.
Many thanks
Kev
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Hi Lenny yep they gave me the quote
Thanks for replying
The valve works fine a new rubber washer for a toilet flush costs about 40p
so I am keen to see if I can get a washer rather than a new valve
Kev
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Hi Chris I didn't measure it
but it would be ralativley simple to remove it
to measure it if anyone has an idea as to a supplier
It is a slightly different profile to a toilet flush washer
Kev
Jan 3, 2008
3,335
5,354
Pakefield, Lowestoft, Suffolk, UK
Looking
once you have removed the valve try soaking it I a large jug of white vinegar, it worked for me. You could probably stop up the outlet hose at the bottom of the van then undo the inlet from the supply and put on a hose, then fill with vinegar that would save you removing it, either way it's the limescale that's the problem and you won't have to take it apart.
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Hi ian yep i soaked it in white vinegar last time
however I think the washer is nearing the time it needs replacing as well
Thanks again for taking the time to reply mucha ppreciated
kev
Sep 26, 2013
4,163
5,121
Market Rasen
Self Build
Since 2003
I fitted a new Truma to a friends van and I could not stop the automatic dump valve from dripping, according to the supplier there was a problem with quite a few of them so he gave me a manuel one to fit. Could be an option.
Jan 3, 2008
3,335
5,354
Looking
kev
Have you considered taking the washer to a plumbing supplier or building material supplier. I cannot think the Truma have them specially made for them and that it is not an item unobtainable elsewhere. Good luck.
Jun 30, 2010
7,924
27,227
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
I got an electric auto dump valve, (needs a live feed if you are going to use it) just cluttering up a shelf in the garage
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Thanks Ian i considered that after I re assembled it the first time lol
I was in a bit of a rush
I was hoping someone else had maybe done that before me and has some success and I could
get info from them
Kev
TheBig1
17,575
42,958
clean it with vinegar, dry the washer and coat with a thin smear of vaseline
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
since 2012
Hi Rang
I dont know if the one fitted uses a feed or not
if you get chance to take a pic of it
and send it or post it here it would be appreciated but if Like my garage its a three day joub to burrow in to it dont panic
Kev
