Cupboard door trims
Discussion in 'Top Tips & Tricks' started by gordoncbrown, Mar 16, 2012.
  1. gordoncbrown
    gordoncbrown Funster
    Oct 2, 2011
    834
    568
    Scotland
    Hi, the trims on the internal cupboards are all coming loose. It looks like they have shrunk slightly. Is it a case of glueing them back in place or buying new trim? It looks like it would be about 30 mm short if glued back in but I find it difficult to see how the plastic trim would shrink this much. Any tips or tricks on this would be appreciated.:Smile:
    Gordon
  2. scotjimland
    Jul 25, 2007
    28,935
    25,616
    if the trims were stretched while being fitted they tend to shrink in cold weather.. not uncommon.. seen it around windows and door frames as well.
    I would remove, soak in a bucket of hot water until pliable, dry off, then refit stretching to to the correct length, then fix in place using a strong contact adhesive..
