crank case brether pipe (1 Viewer)
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
on way back from Lincoln we used 1/2 gallon of oil have now fund that the crank case breather hose is not connected to any thing i cant find ware it goes fiat ducato 2.8 diesel engine it must go back somewhere in to the crank case of air stem but ware :cry:
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
That sounds like a lot of oil to use, is there any sign of leakage?
I am assuming the pipe you have is still connected to the engine, if thats the case, I think the other end of pipe is connected to the air filter somewhere, usually underneath in a very awkward place!
Allan
43,315
49,369
alan has a very good point.
if the pipe is still attached at one end then look at the moulded bends to work out the direction then look for anything it could attach to within its own length.
usually some kind of a metal filter casing, which catches the oil in the crank mist and dumps it back in the engine.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
if its breathing that heavy then i would say the motor is in trouble .
should only be the very slightest of oil in the breathers . its really for air to go in and out as the pistons move .
Wildbill
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
i think you could be right thing the rings are on tare way out i am going to change them i think
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
have you had a compression test done . might be worth it if only to decide .
dont know much about that motor but does it have worn valve guides that can give crank case pressure .
doesnt sound good to me though .
43,315
49,369
right in one rspect Alan, the motors in trouble but Bill gets the coconut.
the breather is mainly to get rid of gas leaking into the crankcase past worn rings and very little to do with whats happening below piston movement.
as one piston comes down, another goes up leaving the same volume for the air pushed down by the first piston.
in an ideal world the crank case could be a fully sealed container....though that would serve no purpose
43,315
49,369
if theres blue smoke under load its rings...
if theres blue smoke on the overrun its valve guides.
if theres black smoke its buggered injectors or blocked air filter
if theres white smoke its water...head gasket time.
basically speaking.
Wildbill
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
as per last post fund out that seal has gone on breather box not terminal yet but only had it a few weeks just dident know where the breather hose went if it need new engine i will drop one in it not the end of the world i am not to worried i can refurbish the motor head rings big ends three day job maximum as i haven't worked on one of these engines but up for the challenge but will wait till it packs in run it in to the ground :thumb:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
yes i agree .
the last thing you want is a blocked breather . i know vw polo,s were terrible for it . and some passats /a80,s you needed a new rocker cover as the seperator was welded into it . mind with care you could remove it and clean it then spot weld back . the polo and some golfs you had to change a pressed in pot on the side of the motor . with out the tool could be a horrible job . but some you could tap in with a small hammer if you had the nack.
this to johns earlier post .
4,924
11,289
Flintshire
Low profile
since 2010
basically speaking.
Usually if it's white smoke we've got a new Pope:ROFLMAO:
Wildbill
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
basically speaking.
thanks John fund a oul seal gone will fix that before ripping it apart and if i am taking the head off it will get new rings cam belt big-end shells the lot
now looking for a lump to refurbish
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
might be worth doing mains ,etc best be safe . yes get another lump then you can go for it .
its hard to know where to stop sometimes .
Oct 5, 2009
348
315
anglesey
Autotrail Delaware
since 1999
yes i agree .
Talk about coincidence was having a route in an old tool box yesterday i found a tool i made out of a short length of scaffold pole with a slot cut out for the breather pipe to fit these VW breather pods i could not remember which vehicle it was for, don't suppose they would clog up so much these days with the modern oils though
Wildbill
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
ok there must be someone out there who knows where that breather hose goes i have taken out the air filter and pipes all the way back to the turbo and still cant see ware it goes :help::cry:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi i only really worked on vw .audi vehicles in my garage .the proper tool had a shaped end to allow a good hit .
i still have the vw press plates etc plus most of the special tools up to about 98 . special drills for drilling valve guides etc still have a souriou dyagnostic computer with diesel connections and a gas analyzer .in fact i almost have full garage equipment . 30 ton press body dozer . all good toys for playing with . never mind recovery equipment . keep thinking i should get a hi-ab for the back of my unit . but slao my wrist and say no dont be silly . i have a pto pump as it was tipper.
Wildbill
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
so in short no :cry:
Melchior
129
82
Amstelveen, Netherlands
Alcove
Since August 2012
Some questions - your answers will help us figure out what is going on here:
  1. From which end is it disconnected? Crank case end or 'other' end
  2. If 'other' end, where do you see the disconnected pipe?
  3. If crankcase end, where is the other connected to?
  4. Is it a JTD, id TD or TDi engine? Which year / reg is the motorhome?
Normally I'd expect the crankcase breather pipe to go between crankcase/sump and camshaft (some may call it rocker) cover.
Mine is a idTD engine so may well be same to yours. I am willing to pass by it on the way home from work to see if I can check breather pipe locations for you and take a pic or two if it will help but need to know the answers first :)
Cheers,
M
Jul 29, 2007
6,551
39,622
Ipswich
RV and PVC
30 years
I wouldn't be surprised if buying a recondition short engine will be cheaper than buying the bits and doing it yourself.
Ian
Melchior
129
82
Alcove
Since August 2012
Stone me I just noticed the OP says he lost half a GALLON of oil, I had understood half a litre!
If that lot had come out the disconnected breather pipe then you'd have it sprayed all up inside the engine bay and probably all underneath and over the back of the wagon and I would certainly think it would indicate a very serious problem :Eeek:
TheBig1
17,611
43,140
I know.....its a special adaption only seen on motorhomes...... it goes to the drivers seat base. because of all the old farts that drive motorhomes:ROFLMAO::ROFLMAO::ROFLMAO:
Wildbill
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
Cheers,
M
1 other end it isent conected to any thing
2 it is a 2.8 JTI g reg 1990 LHD
3 one end still connected to breather box
:thumb:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
as someone changed things so that like years ago the breathers just went down by the side of engine to fresh air .
Wildbill
Nov 18, 2011
11,862
42,910
Planet Earth
A van
Over 25 year's
thinking that this is the case with this one
Apr 19, 2008
1,941
2,919
Kent coast Hythe
Rapido fiat based
brought first van 16 yrs ago
If that lot had come out the disconnected breather pipe then you'd have it sprayed all up inside the engine bay and probably all underneath [HI][/HI]
designed for a rust free chassis then.:thumb:
