Cramer Glass Hob cover fixings
Discussion in 'Motorhome Chat' started by steveclecy, Oct 21, 2009.
  1. steveclecy
    steveclecy Read Only Funster
    Jun 10, 2009
    885
    582
    Wirral
    I wonder if any members could assist me in sourcing the fixings for our Cramer Glass Hob cover.
    We have a three burner gas hob, and on our first trip, the pan supports were placed in the wrong position, and "someone" closed the lid, putting strain on the fixings, which stripped the thread of one of them. I did try a couple of sites on the internet, the only one who replied told me that I would have to buy the complete lid to get the fixings.
    I have tried to upload some pics. The second is of the damaged fixings, the first (v small) is supposed to represent the hob.
    Any ideas anyone?
    Steve
  2. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,691
    5,845
    Mansfield,Notts
    As you have nothing to loose and every thing to gain
    Think about a repair
    There are many products out there that you could pour into the button, screw in the bolt and allow to set, efectifly re threading the fitting. remove bolt and re fit to lid
    Geo
  3. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    Try these people Fasteners and Fixings :: Moss Plastic Parts :: Product Catalogue
    They do every type of plastic screw and gizmo you can think of. They also are happy to send you out a few free samples as well, which might get your cooker fixed for nowt!!!:Wink: :thumb:
    Anyone else should also bookmark this site as they do all kinds of latches, catches, hinges etc etc etc used on motorhomes and caravan all over the world:thumb:
    If you cant find exactly the part your after why dont you but a couple of slightly smaller nuts bolts and washers and drill a hole through the plastic broken bit and use it as a spacer to protect the glass??:Wink:
  4. steveclecy
    Jun 10, 2009
    885
    582
    Wirral
    This last suggestion has merit. The "plastic" bit is in fact metal. scratched as I was trying to grip it to get the threaded machine screw to tighten. I have had a negative reply from O'Leary Motorhomes, so as the first reply states, I have nothing to lose and everything to gain. I will look for some material to pour in and set - perhaps an epoxy resin. If that fails, I may drill out and use another fixing through it. The only problem with that is I would prefer something that was smooth or rounded to avoid snagging things on the closed surface.
    Thanks to both suggestions
    Steve
  5. SteveandSue
    SteveandSue Funster
    Feb 18, 2009
    359
    95
    Guisborough North Yorkshi
    Fixings
    Try doing a search for Polymorph Thermoplastic Granules these were once reccomended by Peter from John Cross Motorhomes looks like good stuff maybe he will be along later to put me right if I am wrong
  6. tony morris
    tony morris Read Only Funster
    Jun 27, 2008
    315
    Calcot Reading Berkshire
    Hi steve have 2 class tops complete that I bought from o'leary m/h brand new never been used both smoked class tops complete with fixing brackets give me a call if interested on 01189413037 Tony
  7. steveclecy
    Jun 10, 2009
    885
    582
    Wirral
    Thanks for the offer, and I may yet take you up, but that is the frustration, I have a perfectly serviceable glass lid, it is just the fixing that has failed.
    Steve
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,707
    17,323
    YO11 2BD
    whatever compound you use to 'rethread' the parts dont forget to very lightly oil the threaded bolt first or even better... a wrap of PTFE plumbers tape or you wont get them apart again.
  9. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,265
    5,247
    East Sussex 01-580-881288
    Yes one could use that but if it gets hot it goes soft, plastic metal or plasting padding might be better and then drill and tap it.
    Peter
  10. big map
    big map Funster Life Member
    Mar 8, 2009
    2,195
    15,606
    Poole
    You could try using a heli-coil insert. These are easily fitted with the correct tools are stronger than the original thread and not effected by heat.
    A small engineering company may supply and even fit them for a small charge.
