Cracking shower floor.
Discussion in 'Tech/Mech General' started by joner8888, Apr 16, 2012.
  1. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    I just noticed a split appearing on the shower plastic floor.
    I`m not a big bloke but:Rofl1: --- i have to pick my little son to use the loo so
    i think all the weight has done it.:Eeek:
    Can i fix it or has it be replaced--it is a 15 year old Autotrail Scout ,so i don`t know if there are any around?
    We never use the shower--i tried it once ,i felt as if i were a escape artist so maybe if not repairable we could board it over with carpet?:Blush:
  2. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,503
    2,609
    UK / Spain
  3. Jim
    Jim Ringleader
    Jul 19, 2007
    26,662
    78,891
    Sutton on Sea
    The shower tray will crack if the support has gone a bit soft allowing movement, so check that the underlying support is still firm before a repair or it will just happen again. :thumb:
  4. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    This is a common problem, and is often a case of the tray not supported enough from underneath.
    I replaced one making a platform underneath the new tray on a board with upstanding sides, that was supported from the base of the van, but that was so we could use the shower.
    If you do not intend using then as you say a board with a mat would do, as long as you do not want it to hold water.
