Yep you can get them off the shelf for about £15 . I replaced mine last year which I bought from webbs of Reading. Simple to do took about 20 mins . RoyThe exterior EHU socket in the van has cracked and it's very hard to pull the lead out without it's disintegration. I have an Autocruise Starspirit, does anyone know if they are a standard item? Can i buy one to fit or do I have to buy bespoke?
Simple undo the four screws , pull whole unit our of side of van undo connecting cables. ( plenty of play) fit new unit .. Exactly the same as on as my stargazer.. Took me 20 mins. Very easy diy job ..I do not know your van but some vans can be a bit awkward making connections inside the van. Worth a quick check before starting so that you can get further advice if needed.
Thanks Khizzie, mind you my Starspirit is a 2005 model, not a Swift. Is your Stargazer that vintage?Simple undo the four screws , pull whole unit our of side of van undo connecting cables. ( plenty of play) fit new unit .. Exactly the same as on as my stargazer.. Took me 20 mins. Very easy diy job ..
Yep 2005 ...so just a different layout from yours..Thanks Khizzie, mind you my Starspirit is a 2005 model, not a Swift. Is your Stargazer that vintage?
