Cover for winter, which is best
Discussion in 'Motorhome Chat' started by elizabethh7802, Sep 15, 2012.
  1. elizabethh7802
    elizabethh7802 Read Only Funster
    Mar 7, 2012
    43
    oxfordshire
    We were looking at buying a cover after finally solving all our leaks (we hope!)
    The Protec ones look great but money is an issue for us and so we cannot afford £400.
    Looked at the the regular ones that are around £100, are these any good.
    The other option is the top cover but again are they any good?
    The other question is what do you do about your solar panels. We have one on top and also use one to keep our engine battery topped up but obviously if we cover them up this is an issue?
    What cover do you have and what are the pros and cons?
    Thanks for your replies
    Liz
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    We never use a cover, it only creates problems, chaffing in the wind, noise if outside the door, and covering your solar panels. If the van is watertight why do you need it?
    • Like it Like it x 1
  3. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Totally agree with wildman, have never used one, I have seen the damage done by too many covers on motorhomes, caravans and cars.
  4. SandJ
    SandJ Funster
    Sep 14, 2007
    1,602
    558
    North Yorks
    Simple
    Naked is the answer :Blush::Blush::Blush:
  5. FULL TIMER
    FULL TIMER Read Only Funster
    May 31, 2012
    796
    712
    NORWICH
    Trust me ,forget the cover, we started to use one of the expensive ones when we bought our first new caravan, unless you have the caravan/van absolutely spotless you will get chaffing marks in the bodywork and dust can work it's way up the sides, with all the faffing about whenever you wish to use the van it either ends up in a heap in the garage or you end up not using the van as often as you would like too.
    All is not lost though we ended up using a product called FENWICKS OVERWINTERING FLUID great stuff when applied it leaves a coating like a very thin virtually invisible coat of wax, this helps to stop the gunge and dirt sticking to your paintwork and will just wash off with a strong solution of thier motorhome cleaner, best bit is the van is still usable at anytime as it is and I assume your solar panels will still do thier job. ...........Mark
  6. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
    We use no cover at any time-hopefully we will be in Spain or Algarve all winter this year :BigGrin:
    Even if in UK van is used all year round.
    Mike.
  7. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    Back in the days when we had two cars we tried a cover on the one parked outside the garage as an alternative to just covering the front and rear windows in frosty weather. I found the cover in a heap under a table in the garage (where it had been for years) a couple of months ago and got rid of it.
    We never covered our first van in winter and don't intend starting now - but we do intend using it as much as possible all year round.
  8. stonflo
    stonflo Funster
    Oct 24, 2011
    110
    24
    shropshire
    Interesting but guess where our TV aireal is on the house what sits on it for toilet purposes. Appart from assasination how do people deal with this . A small cover?
    Mike:Sad:
  9. GJH
    Aug 20, 2007
    27,349
    34,949
    Oops! We have deposits left on our van sometimes - less now that I've cut some high tree branches off. It might be easier/cheaper - and a lot less faffing about - to have the aerial moved :Smile:
  10. stonflo
    stonflo Funster
    Oct 24, 2011
    110
    24
    shropshire
    Unfortunately cant move the aireal or the house.Or the driveway, fornt lawn to small no access from the rear of the property.
    Mike
  11. GJH
    Aug 20, 2007
    27,349
    34,949
    Only one thing for it then Mike. Stop watching telly :BigGrin:
    Sorry, couldn't resist that :Blush:
  12. Chris
    Chris Funster Life Member
    May 5, 2010
    16,758
    37,035
    kent
    A small air rifle:thumb:
  13. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    regarding the bird poo issue can u not fix a small ledge to the side of the house angled upwards with a small gutter so what lands on it washes towards the house wall down into the gutter and away instead of on the roof of the motorhome.
    a bit like a mini car port.
  14. Goldenoldies
    Goldenoldies Funster
    May 10, 2012
    405
    851
    Wiltshire
    We had same problem (assuming you have ordinary type aerial) so we changed to freesat dish in different place areial gone solved.
  15. FULL TIMER
    May 31, 2012
    796
    712
    NORWICH
    The Fenwicks overwintering fluid that I suggested in an earlier post will prevent the birds...t sticking to your roof, it's easy to apply just mix with water and put it in a garden sprayer give the roof a good coating on a dry day and thats it,
  16. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    the only problem i see here is finding a dry day :Doh::Doh::Doh:
