Corner Steadies
Discussion in 'Motorhome Chat' started by ShiftZZ, Feb 22, 2012.
  1. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,824
    36,074
    Leicestershire
    We had in the Autosleeper the wind down/up ones I think they were the same as below..
    [​IMG]
    They were fine, blocks of wood underneath, winder and bobs your uncle..
    On the Rapido we have a different type, not that impressed.
    A) Has anyone ever changed them over?
    B) Is it worth the effort?
    C) How many of you bother with corner steadies?
    D) Is there a right way to use them, should the weight be on the steadies or the tyres?
    Just wondering
  2. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,407
    5,220
    St. Helens MERSEYSIDE
    steadies
    Shiftzz steady on old boy:Laughing:We had them on ourRapido and never ever used them
    but now we have an autotrail with winders and I use them all the time :BigGrin:same type as in your picture if you are thinking of changing speak to an engineer bod there must be loads on this site:thumb: as retrofitting must be done in the right place on the body and they are not made to take the weight of the van :Cool:
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    simple enough to fit.....but you may need to fabricate brackets to extend them lower to the ground.
    mine, on the kontiki, were a simple angle iron box frame with the steadies bolted on and the frame bolted to the locker floors as close to the chassis as possible.
    never allow the steadies to take any weight off the wheels...they are just to stop movement.
    we used them ALL the time as the van would rock in the slightest of winds.
    • Like Like x 2
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,801
    Another factor, if you have an Al-Ko chassis, is whether any make of wind-down steady will fit and/or cause a problem.
  5. pappajohn
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    mine was Alko Graham...thats why they were bolted to the floor.
    • Like Like x 1
  6. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,551
    3,361
    Telford, Shropshire
    The steadies usually fitted to Rapidos are the same type as I have on my Iveco, in fact the ones on my Iveco are off a Rapido. The advantage of these is they are designed to support weight where the wind down type are not. This type can support up to 500KGs each usually and make the motorhome much more stable on site than the caravan wind down type. Place a pad of wood (6" square by 1/2" thick is good) under the steady and lower it till it rests on the pad, then using the supplied steel bar put it through the holes and push down, this will lift the motorhome slightly so you probably want to park very slightly nose up to start with. Because these can carry up to 500KGs each you can use them to level side to side slightly.
    D.
    • Like Like x 3
  7. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    I use a jack under the tow ball
    I use a jack under my tow ball to help support the RV... it helps that I have air suspension on the rear.
    Bob
  8. JohnM
    JohnM Read Only Funster
    Nov 8, 2008
    651
    179
    Central Scotland
    Have the same style on my rapido have used them a couple of times not the best but do the job.I wouldent go to the expence of changing them.
  9. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,259
    5,239
    East Sussex 01-580-881288
    Hilda,
    At your time in life do you really need corners steadies :Rofl1::Rofl1::Rofl1:
    Peter
    • Like Like x 3
  10. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,130
    13,871
    Heavan
    never use them Dave, unless we are in passionate throws, It helps the van to stop rocking. As I said, never used them Dave, however, if I was to be in a passionate throw, might have to. :Wink:
    Easy to change though,
    But why not use a couple of cheap bottle jacks and some wood? or even a scissor jack and an electric drill modified to get them up and down?
    or give up the passionate throws in the van and it won't rock :Cool:
  11. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,954
    2,750
    Englishman in Mid Wales
    I think your old van was pretty simular to mine:thumb: I have to say I have not had the need to use them. my van has a arse up attitude anyway and as I find I usualy park with the nose downhill I would prefer to have them on the front:Doh:
  12. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,954
    2,750
    I guess I'll never need them then:Doh:
  13. JOHNSTEY
    JOHNSTEY Read Only Funster
    Jan 14, 2011
    438
    314
    Edinburgh
    Never used mine...what are they for exactly? obviously not enough movement going on in our van!!
  14. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
    :Blush:
    Nikki would know what you were up to on your own if she came back to the van and the legs were down Paul :Rofl1:
  15. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,583
    22,481
    Narrfoook
    It just so happens..........
    I have a pair of the Alko chassis type AND a pair of the wind up type going spare.. £30.00 for either set :BigGrin:
  16. pappajohn
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    doesn't that put a bit of a dampener on proceedings Paul....having to nip outside and lower the steadies first ? :Laughing:
    • Like Like x 1
  17. Jim
    Jim Ringleader
    Jul 19, 2007
    26,120
    77,208
    Sutton on Sea
    On the few vans we've had that long overhangs we've used them. On a bessacarr and a couple of autotrails, I know they say you shouldn't; but all of them were attached to the chassis and I often used them to help with levelling:Smile:
  18. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,749
    3,252
    Eastbourne East Sussex
    I have the Rapido type on my Rapido :Eeek:
    Only put them down once to see what they were like. I would need a can of WD40 and a mallet to shift them now.:Smile:
    • Like Like x 1
  19. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    [HI]Paul it ain't worth the effort for 2 minute a month mate:Wink::Rofl1:
    [/HI]
  20. grumps147
    grumps147 Funster
    Jun 6, 2010
    1,231
    881
    St.Helens
    We do not have them and so far have not seen a need.
    I think when this was discussed some time ago it may have been Hilldweller pointed to advice not to use them when the wind was very strong, something about without them there was some movement allowed if a sudden very strong gust happened and wind would not meet a totally fixed object, whereas with steadies there was a possibility of it blowing you over if strong enough.
    However, I cannot get to grips with the physics as to why this should be the case, I just know if it will blow large artic trailers over, respect the wind and find somewhere sheltered.
    • Like Like x 2
