Ber090
Having worked out that I need 2 x 4mt of 10mm and 2 x 4mt of 25mm can anyone point me towards a sensible price and source please.
Thx
Bernie
Thx
Bernie
25mm copper wire? What are you building a new power station?Having worked out that I need 2 x 4mt of 10mm and 2 x 4mt of 25mm can anyone point me towards a sensible price and source please.
Thx
Bernie
r you sure about 25mm, that is TOO BIG for domestic use and is VER HEAVY, capable of 1000s of volts, amps
2.Inverter 1000w pure sine wave 4m run to batteries needs 25mm so the cable size charts say!
Bernie
Thx Dave but my Aviano 728 is a nightmare to find space for the inverter. Only option at present is inverter in garageBER090, I'd suggest you put your inverter as close to the batteries as possible and run a 230V lead from it to where you want the power.
D.
Bald as a coot the missus!Sounds like a 10kW inverter so his wife can boil a kettle while drying her hair.
25mm2 is tiny stuff, try working with multiple pole 400mm2 cable25mm copper wire? What are you building a new power station?
Thanks to you all for your replies. The cables for interest and comments are:
1. 3 x 100watt solar panels via 30amp mptt reg ( when it arrives from China) 10mm cables to batteries is what comes up for 4m run with 3% loss.
All square section. Thx Dave!
Cover your 400 & raise you to 7,200mm2 aluminium. I saw a 15" Stilson dropped across a pair of those carrying 50v. The Stilson and both busbars melted. It covered the place in molten aluminium. It was very exciting (from a distance).25mm2 is tiny stuff, try working with multiple pole 400mm2 cable
as and when i need 35mm2 and 25mm2 cable, i often use welding cable. about £6 a metre on ebay
http://www.ebay.co.uk/sch/i.html?_f....Xwelding+ca.TRS0&_nkw=welding+cable&_sacat=0
