COORDINATE CONVERTER
Discussion in 'Motorhome Chat' started by martin2603, Sep 5, 2015.
  1. martin2603
    martin2603 Funster
    Nov 25, 2013
    328
    288
    kent
    Advise please, My Sat Nav is degrees minutes and secs, almost all European locations are in decimal.
    Is there a reliable download, for converting, I have tried several without much success.
    Martin
  2. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,967
    • Like it Like it x 1
  3. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,508
    2,731
    Surrey
    What sat nav do you have? Most can be set to do either method.
  4. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,698
    2,173
    Scotland
  5. NickNic
    NickNic Funster Life Member
    Jan 14, 2014
    5,823
    11,977
    Kettering
    There are a couple of decent ones around. If you have an iPhone or iPad I use this one which works well:
    https://itunes.apple.com/us/app/coordinates-converter-free/id429253366?mt=8
    The free version just supports digital degrees and degrees/digital minutes but if you buy the full version for a whole 79p then it does DMS which is what you need, as well as a couple of other methods.
    There are lots of places online that will do it for you but obviously they are of limited use when you're travelling
  6. chaser
    chaser Funster
    Feb 16, 2013
    7,700
    8,763
    uttoxeter
  7. meanders
    meanders Funster - Life Member Life Member
    Jun 28, 2008
    570
    344
    Ipswich, Suffolk
    We've got both Tom Tom and Garmin satnavs and you can change the format on both. First time I looked on the Garmin, I couldn't find it but a bit of digging around told me how. Google for 'coordinate' for your make and model.
  8. Zepp
    Zepp Funster
    Jun 22, 2008
    751
    1,005
    Portugal For Now
  9. martin2603
    martin2603 Funster
    Nov 25, 2013
    328
    288
    kent
    Thanks for all the help, I actually have Snooper into which I have inserted the 'Camper Chip' . It was originally the Truck Edition. I will have a go at the settings. and also the phone apps.
  10. namwaldog
    namwaldog Funster
    Jan 2, 2015
    488
    799
    Cumbria
    I have formulated a converter in Excel which I have then turned into to a PDF document of six pages which could be printed off onto 3 pages of A4 (printed both sides) if required.
    Looks complicated but fairly simple really. Find the page containing the correct minutes across in green, then the correct minutes down in red and where they cross that is the decimal. The degrees obviously stay the same.
    EG. 6° 21' 44" look on page 5 for 44 in green across the top, follow the column down to 22 on the left in red and read off the number ie 0.378890 so the decimal degrees is 6.378890
  11. Dorwyn
    Dorwyn Funster
    Aug 19, 2013
    604
    323
    somerset
    I'm sure I've entered the decimal into my Tom Tom and it worked fine. Have you tried entering it into your sat nav?
  12. MikeandCarolyn
    MikeandCarolyn Read Only Funster
    Mar 18, 2008
    2,171
    1,463
    Worle,North Somerset
  13. wingman
    wingman Funster
    Feb 10, 2013
    1,024
    2,593
    Romford, Essex
    This is timely! I've just bought a 79p coordinates converter for my iPhone 5. I have a Navman SatNag and it doesn't (to my knowledge) have the option for decimal degrees. This was a pain recently, because the All the Aires book is in decimal (n). Why they can't use good ol' fashioned degrees and minutes I don't know!
    Don't normally use many Aires, but decided to bash them this year and as my CoPilot ( which does take other formats) gave up the ghost, I had to revert to the NavMan.
Similar Threads
  1. Tricky Dicky
    9
    354
  2. Dee 123
    7
    404
