Cooker ignition (1 Viewer)
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Used the ignition button to light a gas ring an hour ago and it worked fine. Now gone to boil a kettle and its not working.
Anyone any idea whats happened please?
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
Is the ignition button firing but not igniting the gas jet?
Nice dog by the way! :)
irnbru
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Thanks @Oriel hes almost 13. Yours looks young. :) No the button isn't firing at all.
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
Its a photo of him as a pup... he's 3 1/2 now and full of fun and energy. They're fantastic dogs aren't they?
Sorry I can't help with the ignition - I had my burner not lighting which turned out to need a bit of a wipe under the gas jet. No doubt someone will be able to get your ignition firing :)
irnbru
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
@Mickx It works through the 12v volt im sure but that's on and batteries are good and full
Mar 26, 2009
8,162
11,221
Yr Wyddgrug
Hymer B678DL
Since 2009
I had the same problem in France a couple of months ago and resorted to a cigarette lighter. I waited until I got home to dismantle the cooker. Among the many things it could be I suspected either switch or the ignitor unit. After a couple of fruitless hours trying to release heat welded screws and nuts I took the easy route and bought a hand held igniter. This will suffice until the winter when I'll have more time. Not the answer you're looking for but probably a good addition to your kitchen utensils drawer until you can get the van into a dealer/repairer.
lunarman
2,156
2,451
South Glos
since 1994
We have a similar problem with our smev oven intermittently. When SMBO washes the hob and then tries to light the it when it is still wet the fuse supplying the oven and kitchen lights blows. Let it dry out and change the fuse and all is well until the next time she forgets.
I assume its something to do with water shorting the sparker.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Getting the igniter electrodes wet will not blow a fuse (although it will stop them sparking). If a fuse has blown something else is causing it.
Jun 29, 2015
3,477
57,396
Southampton
caravan (for now)
on and off since 1984
most motorhome cookers have the ignition unit at the back, to get to it you will need to move the cooker out of position, does the button make a slight click when pressed? try pulling the knob off and pressing the stem, you may be able to hear a slight click, if you do then the button is OK. Now if you want to go deeper and you have a multimeter ,shut off the gas and electricity then you must unscrew the cooker and pull it out a bit, not too far as the gas and wires will be connected if you are lucky you will see the ignition unit on the back of the cooker. As long as you can get to the unit check for 12v supply (turn it back on for the test but not the 240v if you have it) then check if 12v is coming back on the wire from the ignition button. If no power getting back to the unit, the button is faulty. If there is 12v coming back and no spark then the ignition unit is faulty.
If you do not have a multimeter, the you are probably not competent to do this! buy a bbq lighter and get the dealer to check it when you are home.
Good luck
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
If you have a Sargent system the ignitor is powered from the EM50 unit.. I have had three fail ..
irnbru
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Thanks everyone. I'm guessing it must have got wet. I moved location and when I arrived it started working again. If it ever does it again I will know to wait a while. :)
Shrimp
May 27, 2015
3,986
33,435
Bedfordshire, UK
Hymer B584
Long time
Mine sometimes won't work, after a clean out of the 'rings' it usually behaves. I also have a sparker in the drawer for emergencies!
