Cooker igniter (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
Just spent a few days away only to discover the first time we tried to use the cooker that the electronic igniter wasn't sparking. No problem as we just used a match but I obviously want to fix it and I know it was working the last time we went out about a month ago. All the other igniters for the grill, rings etc are working fine.
Apart from sticking my head in the oven (aided by a helpful push by she who must be obeyed) I haven't done anything yet. Can anyone offer me any advice on how this thing comes out and where I might get a new one? Any help would be massively appreciated.
Many thanks, Jerry.
old-mo
Extra Special
16,343
93,570
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Perhaps a bit of burnt food.. (Not insinuating your misses burns owt.. ;):D)
Has dropped down and is lodged in the igniter..
Worth a look,,,, or perhaps a wire come adrift.. (y)
Apr 12, 2010
4,809
51,608
Bury St Edmunds, West Suffolk
Weinsberg Cara
since 2007
I just had the same problem. Just fixed it. Take the screws out of the burners, not as easy as it sounds, (I had to use WD40) and clean the crud from underneath of all the burners. Replace and Hey presto, it all worked again. PS I had to use new screws.
Phil
scotjimland
2,250
9,767
A Woosh bang
So it's just the oven igniter that isn't working ... ?
as the igniter unit is common to all burners.. Same advice as Mo.., just bit of crud or loose wire
also bear in mind.. the oven burner won't ignite with the oven door closed.. there is a safety interlock switch on the door that could be stuck ..
Badknee
7,406
411,952
notloB
Vantage Neo
Living the dream.
Check it's getting to "earth" as it needs to "spark" to light the gas. Just like a spark plug in a petrol engine.
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
Thanks Paul, you were on the right lines with the spark plug analogy. The gap was too big and I closed it and hey presto, it works! Not sure what makes it open up in the first place but I'm grateful for everyone's help. Also one of the terminals was touching its mounting plate and in closing the gap I moved this away. I don't know if that was significant too.
All done. Thank you Funsters. Jerry
