Cooker hood extractor wiring on switches (1 Viewer)
Jul 31, 2014
1,928
3,240
West Yorkshire
EuraMobil Activa 820HS
I have a cooker hood/extractor which has three switches.
Left switch for the left downlight, middle switch for the extractor and right switch for the right downlight.
The left switch doesn't work.
The right switch operates both left & right downlights.
The middle switch operates the extractor fan as it should.
I've been trying to find out if the left switch is faulty or if it has been bypassed to just use one switch for both lights.
Unfortunately, I didn't have time to try switching the wire terminals on the switches today but took a photo of the current wiring to remind me when I'm next in the van.
For the electrical-minded among us, what do you think?
Aug 6, 2013
11,931
16,514
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Looped wire = 12v power
Thin wire with rubbish crimp = fan
Remaining wires on extreme outer switch connection = one to each light.
I can't see any alteration to the switch wiring so any L - R linking must be directly from light-to-light.
GAVLAD
Jul 31, 2014
1,928
3,240
West Yorkshire
Thanks Tony
Do you think it's the switch then?
I can't understand why one switch is powering both lights when the othe switch isn't working.
Looks like I may have to take the extractor off and open it up to check and see
Traveller_HA5_3DOM
422
323
Following the Sun
Hobby Premium 65GE
since 1985
From a practical point not sure why anyone would want one light at a time. The middle switch was wired by someone with different kit to the rest of it but motorhomes are strange in the fact that they use different colours for live and return on the 12v systems to what we expect from our contact with 240v. Quite why someone would use all red cable for everything is beyond me. A little time with you multi tester should enable you to draw the circuit on paper and then work out what will give you Independent left and right lights. The switches are easily tested with you meter to see if they are faulty. If you fold a piece of masking tape round each wire you identify and disconnect it will enable you to either return to as you are or change them.
GAVLAD
Jul 31, 2014
1,928
3,240
West Yorkshire
Thanks Traveller - the lights are pretty bright and to be fair, I could manage with only one on. However that's not the reason for wanting to sort this. It's that I have a switch that doesn't work.
The previous owner has probably
Not bothered or has had an issue and done something to bypass it rather than sort it.
I can't see anyone stripping it all down to change it for any other reason.
Will try with multi meter and will update once done.
Thanks again
GAVLAD
Jul 31, 2014
1,928
3,240
West Yorkshire
Just thought I'd give you all an update on this.
After checking that all wires and switches worked, we found that the white wire which is from the right hand light and going into the top right hand block connector, should in fact go into the block connector where the brown wire goes into. (3rd one down)
On doing so, the switches now work as they're designed to.
Someone has gone to a lot of trouble, stripping the cupboard and extractor fan unit to swap this wire, just to have one switch turn on two lights and have the other switch redundant.
I know, as it took me a lot of trouble finding the problem!
Anyway, all's well that ends well as they say and thanks to my trusty Dad for his help!
GAVLAD
Jul 31, 2014
1,928
3,240
West Yorkshire
Yes we noticed that however there's two feeds. There's the brown & blue which traced back is in a white flex like household 230v and there's also a red & black auto wire.
We thought that maybe the latter came from the main control panel.
