Cooked Battery
Discussion in 'Tech/Mech General' started by Rob e Lee, Jan 7, 2014.
  1. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    435
    510
    Just been in Motorhome to check everything is OK when I noticed a smell of 'rotten eggs' and immediately suspected Leisure Battery and sure enough I was right!
    I always leave Motorhome connected to mains hook up at home and I assume charger - Trickle Charges. Is it possible to overcharge doing this? I recently checked fluid levels in battery and all seemed ok - I should say that my second Leisure Battery failed about 6 months ago and I have just been using 1 x single since. Both batteries were/are the same age three and a half years old.
    Any info as to how to check charger would be helpful,
    Thanks,
    Rob
  2. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    Have you got access to an ammeter?.....put that in line with the pos battery lead and see what the reading is....if its a trickle charge it should be roughly 1 amp or less...
  3. Rob e Lee
    Rob e Lee Funster
    Apr 16, 2012
    435
    510
    Thanks for quick reply. I have and I will check it out tomorrow.
    Rob
  4. acting_strange
    acting_strange
    May 16, 2010
    3,398
    2,568
    North Hykeham
    remember you have to take the lead off the battery and connect one lead to the battery lead and the other to the battery post....(in series) otherwise you get no reading....and if you get a neg reading just swap the leads over
    • Like Like x 1
  5. cmcardle75
    cmcardle75 Read Only Funster
    Jun 8, 2012
    670
    263
    Reading
    It would be safer to measure voltage if not used to using electronic test gear. With the charger on, the voltage should be between 12.6V and 13.7V. If over, the charger may not be smart enough to be left connected. This assumes the battery is definitely fully charged.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,320
    YO11 2BD
    if one failed six months ago and this one is now overcharging i would definately be looking at the charger.
    Unless, of course, both batteries are coming to the end of useful life
  7. Serendipitous
    Serendipitous Funster
    Aug 4, 2012
    322
    266
    Devizes
    Agree, best to use a voltmeter.
    Standard lead acid cell float voltage is 2.25 volts DC. 12volt battery has 6 cells therefore normal float voltage is 13.5 volts.
    Normally the cell voltage should not normally exceed 2.45 volts per cell = 14.7
    Charge voltages can depend on the type of charger used and how sophisticated. Simple ones will only provide a fixed voltage that may appear to rise as the battery charges up and the current drawn reduces. Smart ones have a voltage profile programmed in so that the charge function is optimised.
    Have a look at Wikipedia http://en.wikipedia.org/wiki/Lead–acid_battery
