Converting To Led Lighting
Discussion in 'The Beginner' started by Rooky Vanner, Jun 1, 2015.
  1. Rooky Vanner
    Rooky Vanner Funster
    Mar 23, 2015
    80
    116
    North Nottinghamshire
    Hi All
    We have an Elddis 140 (08 plate) and I am thinking of converting to led lighting. Can I just buy bulbs that will fit our current fittings, do I need to change the fittings? (downlighter spot lights) and if so where do I get them from?
    Total learner here but bought solar panel and want to reduce my power use for camping without hookup. We are 'without hookup' rookies but willing to learn!!
    Many thanks
    • Like Like x 1
  2. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    just change the bulbs, simple job.
  3. scotjimland
    Jul 25, 2007
    28,934
    25,589
    as said.. I did all of mine and sourced LEDs from this company, as recommended by others on Fun
    http://www.atenlighting.co.uk/caravan-motorhome-lighting
    not a cheap job.. I had 11 to change .. you can buy cheaper.. but cheap LEDs don't last. .. do it once do it right .. (y)
    I bought two to try for colour.. and settled on warm white..
    if you tell us what lamps you have can advise on replacements..
    • Like Like x 2
  4. Jimbohorlicks
    Jimbohorlicks Funster
    Sep 3, 2012
    713
    964
    Cheshire
    there are some warm white led's in poundland-worth a try-forget the type but they have 2 pins
  5. Rooky Vanner
    Mar 23, 2015
    80
    116
    Thanks for help... Photo of fittings to follow
    Many thanks
  6. Rooky Vanner
    Mar 23, 2015
    80
    116
    Ok
    Here is the picture you have been waiting for... the bulb is 2 pin and wait for it 35mm in diameter?
    Here's hoping.
  7. Badknee
    Badknee Funster
    Aug 25, 2014
    3,711
    15,949
    notloB
    As has been said before, don't buy cheap 12volt ones, buy 8 to 30 volt ones, they are the ones that last. image.jpg
    • Like Like x 1
  8. Rooky Vanner
    Mar 23, 2015
    80
    116
    Grand stuff thanks a lot for all the help. I'm on it!!
  9. Badknee
    Badknee Funster
    Aug 25, 2014
    3,711
    15,949
    notloB
    Or there's warm white, I put warm in the lounge area and cool in the kitchen and bathroom, not cheap but the power savings are massive. The indicator was 8.6 watts for halogen and 0.8 watts for LED. image.jpg
  10. Rooky Vanner
    Mar 23, 2015
    80
    116
    Hi Badknee It's for the lounge area so gone for warm white.
    Next I am checking what is in the roof lights.
    Seems a lot easier than I expected!!
  11. Jimbohorlicks
    Sep 3, 2012
    713
    964
    Cheshire
    you can change those for the ones in poundland -they are warm white with 12 leds-had no trouble with mine so far (2years).
    for others i went on e bay
  12. Rooky Vanner
    Mar 23, 2015
    80
    116
    Brilliant thanks
    Great forum this!!
    Nice people...well sometimes..Ha ha
  13. Rooky Vanner
    Mar 23, 2015
    80
    116
    Now for your next test? What do I replace this with????
  14. hovisbrown
    hovisbrown Funster
    May 15, 2012
    29
    19
    East Sussex
    Ditto I've got 2 like that I'd like to replace.
    Regards
  15. peterc10
    peterc10 Funster
    Jul 5, 2013
    3,385
    2,441
    Tunbridge Wells
    That looks like what is called an MR11 bulb which is 35mm diameter. The one suggested by Badknee won't work because it is for a fitting with a G4 halogen bulb and the prong connectors are in the wrong place for your fitting. Just search MR11 LED on fleabay and you will come up with hundreds of hits. Try to choose one in the UK or you will have a long wait to get it from China.
  16. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    walthamstow east london
    to replace those buy 5m of led strip from ebay and remove all the electronic parts from the fitting ,you just need the live and earth that enter the fitting i cant see if those lights have switches if yes leave the switch in situ and use the two wires that come out of the switch to connect to the strip
    i used as much as i could get inside the fitting to get a bright light but you may need less depending on its use
    the strips come with two wires on for the first connection and can be cut to length every 3 leds there's a mark on the tape where you can cut
    at the end of each section there are two solder dots you can solder new wires onto or you can buy connectors which clip on
    led's are polarity sensitive but if you connect wrong it will not damage them just reverse the wiring
    the strips are self adhesive but i added a couple of spots of glue as well
    it sounds harder than it is its taken me longer to type this reply
    • Like Like x 1
  17. Rooky Vanner
    Mar 23, 2015
    80
    116
    5m strip ordered, mr11s ordered, fantastic advice, just exactly what I wanted!!
    Saved me a fortune and I am very grateful to all of you, The strip idea was superb, never thought of that...
    Thanks again.
  18. Drexxer
    Drexxer Funster
    Oct 26, 2014
    257
    281
    Lincolnshire
    Hi,
    I have 4 down lights in the cab / dinette area, in your opinion would the G4 10 led's be too bright in the warm white? or would I be ok with the 6 Led one's
    Andy
  19. scotjimland
    Jul 25, 2007
    28,934
    25,589
    I bought the 10 led warm white G4s and they are very bright.. great for reading.. but I think the 6 led would probably adequate .. buy a couple to try ?
    • Like Like x 1
  20. Badknee
    Badknee Funster
    Aug 25, 2014
    3,711
    15,949
    notloB
    I haven't changed mine as they don't use a great deal of power.
