Control Panel
Discussion in 'Tech/Mech General' started by rich g, Oct 12, 2016.
  1. rich g
    rich g Funster
    May 29, 2014
    243
    357
    Worcester
    IMG_0207.JPG The control Panel above is not working it won't turn on I just get a blue light flashing in the top right slot ,I have connected it to electric hook up and same result,so I have no power. Any suggestions please
    rich
  2. hilldweller
    Dec 5, 2008
    27,230
    26,223
    Macclesfield
    Many times in the past people have been told "remove from wall, unplug, wait a minute, plug in and try again".
    You could also check your leisure battery volts first.
  3. K9Brian
    K9Brian Funster
    Aug 2, 2010
    612
    608
    South Manchester
    Give Sargents a ring - they've been excellent talking me through problems. If possible phone from the van in case they ask you to try certain tests.
  4. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,842
    11,017
    Glasgow
    • Like Like x 1
  5. rich g
    rich g Funster
    May 29, 2014
    243
    357
    Worcester
    I rang Sargent and they told me the light was flashing because to much power was going into the battery and the power was stopped to protect the battery from frying
    So they said cover the solar panel and if the control panel returned to normal the regulator on the solar panel is not working.
    I have just had a tow bar and electrics fitted is it possible they caused the problem or is a coincidence .
  6. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    5,105
    9,740
    Lorca,Murcia,Spain
    Can't really see how having towbar electrics fitted could cause it ? Probably a coincidence.
  7. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,609
    22,741
    Narrfoook
    Do as Brian Said.. remove from wall, unplug the ribbon cable ( it simply pulls off and is a plug so very easy ) count ten and refit
    I ( as others will tell you ! ) have extensive experience of Sargent systems !!
  8. rich g
    rich g Funster
    May 29, 2014
    243
    357
    Worcester
    I rang Sargent and they said cover the solar panel and if the control panel works its the charge controller/regulator.I have had someone round yesterday and he can't find it,so he has disconnected a lead from the leisure battery to the panel hopefully(i will have to wait until the sun comes out to test it).So at least i will be able to go on holiday,then get it booked into get it fixed.
  9. Jaws
    Sep 26, 2008
    18,609
    22,741
    Narrfoook
    I await with bated breath
    As a matter of interest, exactly WHAT lead was disconnected ??
  10. irnbru
    Jun 27, 2013
    5,842
    11,017
    Glasgow
    Why dont you do as suggested above? You have asked for help so why not try it? You have nothing to lose.
    • Like Like x 1
