control panel beeps when accelerating
Discussion in 'Motorhome Chat' started by Debbi, Mar 22, 2010.
  1. Debbi
    Debbi Read Only Funster
    Mar 22, 2010
    3
    We have recently bought a swift kontiki 655 (2003) and really love it, but when we are travelling the control panel beeps everytime we accelerate - the dealers we bought it from are great and they are going to have the mh back for a couple of days to investigate - just wondered if anyone else experienced this and if so what the problem was.
    Also we have two brand new leisure batteries which the dealers gave us after discovering the leisure batteries we had were no good. We would like to do some wild camping and wonder how long the batteries last if you are using the heating, lights fridge etc- obviously it depends on how warm the mh is inside and how often the fan cuts in but could we be looking at a couple of hours or anything up to 24 hours, or longer? I imagine the heating fan is a big drain on the batteries.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,961
    17,639
    YO11 2BD
    firstly welcome to the asylum.:BigGrin:
    cant help with the bleep but.....
    you dont say what van you have or what size the batteries are ?
    unless you have a compressor fridge, it wont run on 12v unless the engines running so no battery usage there. you'll need to run it on gas only if wilding.
    if the batteries are 110ah each then you have 220amps to play with.
    if your lights are standard halogen lamps then expect around 1 to 1.5amp per lamp per hour.
    heater fan will use the most...between 3 and 6amps or more per hour and will soon flatten the batteries.
    water pump..7 to 8amps per hour but its only running a few seconds at a time so negligible usage.
    TV....maybe 1 to 2 amps depending on size and type.
    never let the batteries run below 50% discharged at the very most or they could be damaged, so that 220amps is really 110amps.
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,363
    5,388
    East Sussex 01-580-881288
    Your slipping John, lost your glasses again!:Rofl1::Rofl1::Rofl1:
    Peter
  4. pappajohn
    Aug 26, 2007
    29,961
    17,639
    YO11 2BD
    you lost me peter ?
    DUH!!!!!!
    just realised what you said.
    its late and the grey matter is tired...and a need new goggles.
  5. ddavewoods
    ddavewoods Read Only Funster
    Jan 9, 2010
    109
    South West
    could it be one of the water tank sensors ?
  6. buttons
    buttons Funster
    Aug 27, 2009
    13,639
    11,285
    Hertfordshire
    My Nissan does that. It beeps just before the Rev limiter cuts in.:Smile:
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,363
    5,388
    Hi Debbie
    We have seen this problem before.
    It is common for the vehicle to send a spike to the panel which in turn may make the unit beep.The way to resolve this is to remove the panel and the electrical connections to the rear and by simply refitting it all will stop your beeping (re-booting).
    You may find that you have to repeat this from time to time.
    Regards
    Glenn Harris Workshop Manager
  8. Debbi
    Mar 22, 2010
    3
    Hi Thanks for this we will give it a try.
    Debbi
  9. Debbi
    Mar 22, 2010
    3
    My husband has just told me the dealers have already disconnected the panel and tried it with a different panel but it still beeps.
    Its strange because it is only when you pull away quite sharply.
    Debbi
