scotjimland
- Jul 25, 2007
- 2,247
- 9,759
- A Woosh bang
Reference to these is regularly made in reverse polarity threads.. and the reason given why reverse polarity isn't an issue.. but I've never seen one.. frankly I don't think there is such a socket..
reverse polity isn't an issue in continental vans with Schuko sockets simply because they don't have a switch and the plug is symmetrical..
The CEE 7/3 socket and CEE 7/4 plug are commonly called "Schuko". The socket (which is often, in error, also referred to as CEE 7/4) has a predominantly circular recess which is 17.5 mm (0.689 in) deep with two symmetrical round apertures and two earthing clips on the sides of the socket positioned to ensure that the earth is always engaged before live pin contact is made. The plug pins are 4.8 by 19 mm (0.189 by 0.748 in). The Schuko connection system is symmetrical and unpolarised in its design, allowing line and neutral to be reversed. The socket also accepts Europlugs and CEE 7/17 plugs. It is rated at 16 A. The current German standards are DIN 49441:1972-06 "Two-pole plugs with earthing-contact 10 A 250 V≅ and 10 A 250 V–, 16 A 250 V∼" (which also includes CEE 7/7 plug) and DIN 49440-1:2006-01 "Two-pole socket-outlets with earthing contact, 16 A 250 V a.c." It is also used in Albania, Austria, Bosnia and Herzegovina, Bulgaria, Chile, Croatia, Denmark, Estonia, Finland, Greece, Hungary, Iceland, Indonesia, Iran, Italy (standard CEI 23-50), Latvia, Lithuania, Luxembourg, Republic of Macedonia, Republic of Moldova, the Netherlands, Norway, Pakistan, Portugal, Romania, Russia,[46] Serbia, Slovenia, South Korea, Spain, Sweden, Turkey, Ukraine, and Uruguay.
"Schuko" is an abbreviation for the German word Schutzkontakt, which means "Protective contact" - in this case "protective" refers to the earth.
If you have a continental van and the sockets have been changed to 13A single pole switched, then you have lost this safety feature..
IMO it is safer to keep original Schuko sockets and fit Schuko plugs to your appliances..
