connecting two leisure batteries
Discussion in 'Motorhome Chat' started by PhilandMena, Aug 27, 2009.
  1. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,902
    Corby, Northants
    Hi, I have one leisure battery with a couple of red wires going to one terminal, of which one is fused ( I guess this is to do with charging and/or supplying power to auxiliary equipment in the Motor Home) and a single black wire to the other terminal. I’m about to add another battery of the same size and output! Would the correct method of connection be to leave the red wires already attached and disconnect the black wire and connect it to the corresponding terminal on the second battery and then add a new red and further black cable between both batteries? i.e. red to red black to black with an additional fuse (30 amp) on the red.
    Does this make sense! And if so why!
    Thanks in advance,
    Philip
  2. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,351
    5,368
    East Sussex 01-580-881288
    Hi Philip,
    You have it in one although there is no need for an extra fuse providing it is the main output lead.
    Peter
  3. sinbad1
    sinbad1 Deleted User
    have a look here just put your requirements in
