Confusion re; Tyre Pressures Hobby 650Ec
Discussion in 'Tech/Mech General' started by emmitdb, Feb 15, 2014.
  1. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,888
    1,770
    Cornwall
    Greetings,
    Yet another question comes off the conveyer belt from this newbie motorhomer.
    On the drivers door jamb of our 2007 Hobby 650Ec is a sticker, in both Italian and French (which to me would indicate that it was put on by the manufacturer, Fiat) to state that the tyres, which are Michelin Camping XC 215/70R15C, should be inflated to 5.5 bar or 79.5 lb sq. inch to both the front and rear.
    However, in the user manual accompanying the vehicle, the data states that the same tyres fitted should be inflated to 4.5 bar to the front and 5.5 bar to the rear.
    Simple Question, which I know could result in different answers, which one is right.
    Regards
  2. Hercules
    Hercules Read Only Funster
    Sep 30, 2012
    44
    48
    SWANSEA
    That sounds like the maximum pressure they should be inflated to.
  3. Popeye
    Popeye Funster
    Sep 5, 2011
    7,912
    18,011
    New Forest
    I believe Hercules has it in one, my van also has 5.5bar or 79.5 all round.
    I ran it like that for a few weeks and then reduced it down to 72 front 68 rear and the ride improved considerably.
    I'm in a geist Silver Spirit with the 3.0 litre lump and the larger wheels 16 inch I think.
    Fuel consumption improved marginally too.
    .... Griff :thumb:
  4. Scattycat
    Scattycat Funster
    Jan 3, 2013
    844
    1,184
    Mayenne, France
    I have a similar problem.
    But if I look in the handbook it gives me 2 sets of pressures for my van.
    I've changed mine to the lower pressure and the ride is much more comfortable with, for me, no noticeable loss of stability
  5. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    I emailed Michelin and they gave me different pressures based on my max axle weights.
    it changed the ride in the van considerably.
  6. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,888
    1,770
    Cornwall
    Greetings Again,
    Thanks Guys, seems to be a consensus that a less inflated tyre equals a more 'comfy' ride, which I would have expected.
    I was surprised to read Popeyes comments that on deflating his tyres from the Max that he thought he got better economy. I always thought that the higher the pressure, the less rolling resistance, but there you go.
    I'll take some air out now having struggled to get it in up to 5.5. The connector kept blowing itself off the valve!!!:Eeek:
  7. ericonabike
    ericonabike Read Only Funster
    Jan 19, 2012
    430
    267
    Leicester
    See my thread and the advice from Michelin. Suggested 56 front and 80 rear - whereas both axles, with full load, 'weighed' the same. Seems they will always suggest you run rear at max, whatever the axle weight.
  8. SUGGY
    SUGGY Funster Life Member
    Nov 23, 2011
    956
    1,689
    scunthorpe
    I have tge fendt version of the hobby 6.8mt , Transit based
    i am running 55 psi front 65 psi rear , rides well and economical ,:Smile:
