condensation under top bunk matress
Discussion in 'Motorhome Chat' started by 656, Feb 2, 2009.
  1. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    I hope someone has a solution to my problem. We have a Carioca 656 with fixed bunks. The top bunk suffers from condensation after being slept in. We have to prop the mattress up in the morning to dry it out. However, I need to solve this problem permanently. Any ideas?
  2. brianju
    brianju Read Only Funster
    Sep 18, 2007
    171
    35
    Hampshire Hogs now in Mid Wales
    If the mattress is on a solid base there would be no air flow - you could try fitting slats for the mattress to sit on.
    Hope this helps.
  3. scotjimland
    Jul 25, 2007
    28,993
    25,686
    Suffolk
    Hi Dave
    I presume it's not a slatted base .. ?
    if it's a solid plywood base I wood look at drilling a series of ventilation holes, say 20mm ..
    Another option is to lay silver insulation on the base, as used by builders for wall insulation.. short term, lay newspaper or cardboard under the mattress..
    Jim
  4. The Kar-Mann
    The Kar-Mann Read Only Funster
    Jan 23, 2008
    66
    in a wood
    Hi we had the same problem on a C I 181 a few years back the best thing we did and the cheapest was to put a towel under it at night then just dry the towle the next day or more of a perminant solution would be trying to change the solid base for beach slats we chose the first it was easier, Good luck
    Andrew:thumb:
  5. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    I assume you mean the underside of the upper mattress suffers condensation when the bottom bunk is used. cover the frame with material to prevent condensation reaching the mattress. Condensation is caused by lack of ventilation and warm air (breath) condensing on colder surfaces.
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,261
    17,929
    YO11 2BD
    got the same problem but its where the pillows touch the end wall. short of drilling holes though the rear wall :Eeek:i cant think of a solution.
    the side wall has a trimmed ply panel on spacers but if i do the same on the end the day cushions wont fit:Sad:
    insulating the base will work in the short term but it really does need ventilation long term
  7. Red Sonja
    Red Sonja Funster
    Oct 27, 2007
    1,134
    529
    Near Dartford
    We got some slats from Ikea cost about £5 and put them under the matress. Solved the problem.
  8. colyoung
    colyoung Read Only Funster
    Oct 26, 2007
    21
    Hull
    Dave,
    There is quite a detailed thread about this problem on the "other"forum(motorhome facts)I don't think anyone came up with a definitive answer though.When warm air hits a cold surface then........nature takes over!
  9. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Us too, we are resigned to pulling the mattress etc down when parking up after trips to let things dry as slats arn't an option.
    Curiously, we replaced the insulation under the bed base ie between the ali ouside and the wood inner, using typical loft type insulation and the condensation was drastically reduce, not eliminated obviously but reduced on our New Years trip, -3/4 outside, coezzeeee inside.
    Si.
  10. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    The secret is ventilation, it does not mater how you do it but the bottom of the mattress must be ventilated. if you look on the sites for boats and ships chandlers you might find your answer there as it is a common problem on boats.
    Doug....
  11. traveller
    traveller Read Only Funster
    Oct 27, 2007
    51
    hello
    How about using those insulated camping mats that used to be used by campers between them & the ground. I have done this behind our settee in the motorhome not so much for condensation but because it feels so cold behind there this cold weather. I have also used this method to line the tops of lockers to prevent condensation forming.
    Traveller
  12. vicdicdoc
    vicdicdoc Read Only Funster
    Sep 25, 2007
    120
    North Wales
    As 'Red Sonja' mentioned - 'IKEA' have adjustable width [slightly bowed] slats which will do the job perfect [and they are cheap !
  13. Terry
    Terry Funster
    Dec 27, 2007
    10,788
    6,294
    South yorks
    Hi has it got a slatted base,or solid ply?if solid change it for slatted :thumb:
    terry
  14. 656
    Jul 30, 2007
    1,150
    291
    The universe
    It has a solid base. Changing to a slatted base may not be as simple as it seems. The IKEA slatted bed bases may be the solution, it looks like thats where we are going this weekend!!!
  15. ned
    ned Read Only Funster
    May 18, 2008
    12
    condensation
    Had the same problem with our hymer544 and posted a thread on MHF. We tried evrything mentioned above until we found a good solution. Go the natural mat company. They do a woven bed underlay. It comes in a variety of sizes and for your bunk size it would be £40. It is brilliant, leaving a breathable gap of 20 between the matress and the plywood base. I will assure you it's worth the money and works perfectly. They use it on bunks in boats.
    Ned
  16. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,421
    5,449
    East Sussex 01-580-881288
    I have the same problem on my boat, I put towels underneath, they get wet!
    You can get some slat type under 'mat' thingy from boat chandlers that are meant to cure it.
    Its the warmth of your body through the mattress onto the cold bed base that does it.
    Peter
  17. 656
    Jul 30, 2007
    1,150
    291
    The universe
    Well, we went to IKEA - thanks Sonja - got some slats for £12.90. :thumb::thumb: I will see how the perform when we gop out in the van next. Thanks to all. Oh, and we can recommend the IKEA breakfast at £1.65 :thumb::thumb:
  18. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    6,077
    3,474
    Eastbourne East Sussex
    If it doesn't work there is a product called AKWAMAT (it really is spelled like that) which is a dutch product that had rave reviews some years back when the drop down beds of Hymers seemed to suffer from this problem. It is still on the market though I don't know who stocks it, possibly boat chandlers.:thumb:
  19. 656
    Jul 30, 2007
    1,150
    291
    The universe
    The Akwamat solution looks good, that will be my next avenue should the present one fail to live upto expectations.:Rofl1:
  20. ray
    ray Read Only Funster
    Sep 24, 2007
    11
    condensation
    We had the same problem with a caravan and our motorhome. I both cases we just put a sheet/pieces of 1/8inch untreated plywood under the matress and never had another problem in years. Simple but it worked for us.
