Condensation in overcab bed
Discussion in 'Tech/Mech General' started by irnbru, Nov 8, 2015.
  1. irnbru
    irnbru Funster Life Member
    Jun 27, 2013
    5,799
    10,970
    Glasgow
    Early this year we appeared to suffer dampness which turned out to be condensation. Now the weather is getting colder its reared its ugly head again and is now forming at the opposite side too. We can see it running down the plastic wall from about halfway up, its that bad its made the mattress all wet. 20151108_111622.jpg 20151108_111622.jpg 20151108_111728.jpg
    The top hopper window is open so how else can we remedy this situation. Fill it with foam? If so how much? Any suggestions welcome.
  2. Badknee
    Badknee Funster
    Aug 25, 2014
    3,732
    16,409
    notloB
    If it is just condensation then heat to dry it out and fresh air to stop it coming back, move everything away from the walls.
  3. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,029
    6,045
    West Sussex
    To me it looks like too much water damage to be condensation, it looks more like water ingress. You may be in need of some serious repair work, to start with you will need to remove the inner wall board to establish the extent & source of the problem.
    • Like Like x 1
  4. Badknee
    Badknee Funster
    Aug 25, 2014
    3,732
    16,409
    notloB
    I'm sorry to say I do agree with Lenny but I hope it is just condensation .
  5. irnbru
    Jun 27, 2013
    5,799
    10,970
    Glasgow
    Im sure its just condensation. We already had it resealed for ease of mind. It seems to be only now that the cold weather is returning. Living in Scotland sees plenty of rain and theres been no wet all summer. The fact we can actually see it and its forming halway up seems to rule out dampness to me but hey what do I know, thats why im here asking more knowledgable folk.
  6. andy63
    andy63 Funster
    Jan 19, 2014
    2,051
    7,729
    south shields
    If its condensation the only answer is insulation and good ventilation ...
    The pictures make it look like it's been present for a bit though...
    Did you get the pump /water leak sorted???
    Andy
  7. rangitira
    rangitira Funster
    Jun 30, 2010
    6,373
    13,139
    Cornwall
    Generally from about December, to middle of March, I have a small fan heater on a timer in the M/H, it gets to "play" 4 times a day (every 6 hours) for an hour. I leave it on the glass top of the hob. That seems to keep the condensation and mould away, not only does it throw out a bit of heat, it also circulates the air about a bit .
  8. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,852
    11,316
    E Yorks
    That doesn't look like 'just' condensation to me either ... if it's forming 'half way up' it could be one of the timber framework spars that run across at that point behind the panelling which is damp and the moisture is coming through from that giving you the impression it's just condensation. Looking at your first photo you can see on the left that the damp area actually goes further left (looks yellowish) in a 'line' ... if it was just condensation or localised damp I would expect the yellowish stain/mark to be equal around the whole of the brown stain, not just go to one side.
    The only sure way to check is to remove the inner panel and have a shuftie - I notice tha tyou've got some sort of fixing coming through - could that be letting some damp/water in?
    Not sure how/what they did to reseal but unless they removed all the old sealant, cleaned up throughly and then resealed it properly it might not be totally water tight.
    • Like Like x 2
  9. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,029
    6,045
    West Sussex
    Not necessarily a good thing as warm air retains more water.
    • Like Like x 2
  10. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,029
    6,045
    West Sussex
    If there has been water ingress resealing is a waste of time unless the inner panels are removed and thoroughly dried out, also the source of the leak needs to be probably established. If it is an older van with polystyrene insulation, water can capillary trough and the source of the leak can be some distance from the damp area.
    • Like Like x 3
  11. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,954
    2,749
    Englishman in Mid Wales
    Thought about trying these out (y) or something similar :cool:
    • Like Like x 1
  12. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,134
    531
    Are you getting the condensation while the MH is empty? Or when you are living in it?
    • Like Like x 1
  13. Judge Mental
    Judge Mental Funster Deceased RIP
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    I need new glasses..thought that read "confessions in an over cabbed bed" or maybe wishful thinking?:)
    Hope you get it sorted!
    • Like Like x 4
  14. irnbru
    Jun 27, 2013
    5,799
    10,970
    Glasgow
    Only when living in it
  15. rb62
    rb62 Funster
    Nov 5, 2013
    452
    6,543
    Shropshire
    That would explain excessive condensation. :whistle:
    • Like Like x 4
  16. Judge Mental
    Sep 2, 2009
    6,782
    6,037
    Sarth London
    really?...so I was right after all!:)
    • Like Like x 4
  17. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,134
    531
    It's tricky when the weather gets colder but you want to stay warm in your MH. We have the temp at about 18° max and wear warm clothes, turn the heating off overnight and if cooking inside have the roof vent open to allow steam out. Ideally you should have vents open at night but it can be impractical. We got around half a pint of condensation off the windscreen and side windows this morning without our exterior screens fitted.
  18. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,804
    1,027
    Cark, Cumbria
    In that case it does sound like condensation. Do you have any idea why?
    We had a problem in the rear over bed lockers in ours (only damp when using it in cold weather), I found the problem was caused by the fact that where the top marker lights were fitted,the insulation had a 2" dia hole in it to accommodate the light. The answer was to get it thoroughly dry & then insulate the area with some very thin insulation sheet. No more damp.
  19. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,091
    5,372
    Guisborough
    The warmer you keep the inside the more condensation there will be, if the overcab is not insulated it WILL form condensation on the cold surface it's just natural, try to insulate any surface that is not already insulated. After that as has already been said, plenty of ventilation.
    Martin
  20. irnbru
    Jun 27, 2013
    5,799
    10,970
    Glasgow
    Insulate it with what? Over it or inside the plastic with foam?
