Computer problem (1 Viewer)
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
Can any computer buff help me PLEASE!!!!!!!!!!!!!!!!!!
I use an external hard drive to store all my files. Everything has been working fine until a couple of days ago. Now when I try to access the files on my hard drive Windows explorer closes down and I can't access my files.
Please tell me what I can do?
Norman
43,326
49,441
it was just a thought Norman......have you tried plugging it into a different USB port.
one port on my lappy doesnt appear to have full functionality for some reason.
sorry cant be any further help.
May 16, 2010
3,213
2,535
North Hykeham
Custom
much more now
Try using a different usb connection cable betwen the two...does the external HD need power? and is it on?
Try it on a different computer/laptop...
X
Xoxoc
Have you tried re-booting your computer? :winky:
normanandsue
normanandsue
1,871
21,571
van conversion
Thanks, I tried that - it made no difference.
Norman
normanandsue
normanandsue
1,871
21,571
van conversion
Tried the first options and it makes no difference.
Have tried on my netbook and it works fine.
the problem is clearly in my computer.
Norman
43,326
49,441
Norman
try a system restore to an earlier date......only needs to be a few days back.
all programs > accessories > System Tools > system restore
that may repair any corrupted/missing OS files on your computer.
if that works then undo the restore and the repaired files should stay put.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
If it still works on another computer then Pappajohn's advice is definitely worth following.
If it fails on all computers, don't despair. I've used this software before now and it works fine.
Basically you download it for nothing, scan the duff drive, and see if it finds anything. If it does you pay online and buy the software, which you can use as many times as you like.
It can resurrect data from reformatted drives - it's pretty powerful.
normanandsue
normanandsue
1,871
21,571
van conversion
Thanks papjohn - whilst thinking what I might do I came to the same conclusion and it fixed the problem just fie.
Many thanks to everyone for your help and advice.
Norman
meanders
Funster - Life Member
2,598
8,414
Ipswich, Suffolk
C class
Since 2004
If you've tried the system restore option above and still got nowhere, then there are four options I can think of:
1. Try plugging the disk in, wait for Windoze to see it and then go to 'device manager'. Point at 'My computer', right click, take the 'manage' option, then open 'device manager' under 'System Tools'.
Look under Disk Drives and you should find the external drive. Point at the drive, right click and take the uninstall option. Unplug the drive, then REBOOT the lappy TWICE letting Windows load fully and sign in each time. Only then reconnect the drive and it should then reinstall and be OK.
2. Check that the disk is getting enough power. Some need the power output from two USB ports.
3. If still causing trouble, then look in Disk Management as in step 1. to check that its not mapping to a drive letter something else is, or has used. If so, right click it and change the drive letter.
4. If all that fails, look in Event Viewer as in step 1. and look under System and application logs for the time the error last occurred to see if it logs any errors. If so, you could search for the error code or post the details here.
Good luck ..... Robin
EDIT: Just read the reply you made while I was typing my reply. Good news. :)
normanandsue
normanandsue
1,871
21,571
van conversion
Robin,
Thanks for your advice - the system restore option worked brilliantly and we are now all sytems go. I think I will use this option first for any future spasmodic problems I have.
Norman
sealski
33
6
West Sussex
VW transporter conversion
4 years
When you plug the external hard disk into the USB drive, does the computer recognise the drive. Try a different USB port and the computer may try and download the drivers again.
Another thing to try, is instead of double clicking the drive letter, try right clicking the mouse on the drive and select open. What operating system you using? If your PC is connected to the internet, with your assistance and authority, I can remote onto it and take a look at it. Oh by the way I am a microsoft developer. If you need further help, send me a personal message.
Sorry just seen that your problem has now been fixed. But if you do need further help, please contact me.
