Computer help Please!!!!!!!!!!!!!!!!
Discussion in 'Motorhome Chat' started by normanandsue, Aug 11, 2012.
  1. normanandsue
    normanandsue Funster
    Dec 31, 2010
    1,311
    4,266
    Dunfermline - Scotland
    I am having problems accessing "My Documents" Every time I click it opens the page but as soon as I scroll down and click on a file - Windows explorer is closing down. Despite googling the problem I can find no solutions to the. Can anyone help please?
    Norman
  2. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,571
    11,754
    Champagnac-La-Riviere
    Try restoring to an earlier date....
    Start/all programs/accessories/system tools/system restore
    Then choose a date when it was working ok. :thumb:
  3. normanandsue
    Dec 31, 2010
    1,311
    4,266
    Thanks Ken.
    Have a problem! The proferred system restore dates are after the "infection" how can I set an earlier date, without restoring factory settings.
    Thanks Ken
  4. normanandsue
    Dec 31, 2010
    1,311
    4,266
    Bump up
    Anyone any ideas please?
    Norman
  5. RonnieJ
    RonnieJ Read Only Funster
    Jun 30, 2009
    111
    74
    Thetford, Norfolk
    If you have Windows Vista or Windows 7, when you get to the System Restore page it does only offer you a few dates but somewhere on the screen you should have an option to 'show older restore points', if you can find that you should be able to choose from several much earlier ones - as long as you don't have a programme that is automatically cleaning out old files on a regular basis.
    Good luck.
  6. normanandsue
    Dec 31, 2010
    1,311
    4,266
    Thanks Ronnie,
    I have looked for such a button but can't find one, it does rather look as if older system restore point are being cleared. I did have one for 15th July but when I did a system restore this option disappeared. Is ther anything I can do other than reinstalling Windows 7?
    Norman
  7. Munchie
    Jul 28, 2007
    8,571
    11,754
    Here is a screen shot click the radio button for choose a different restore point. :thumb: then next
    • Like Like x 1
  8. RonnieJ
    Jun 30, 2009
    111
    74
    Thetford, Norfolk
    If you hover your mouse over the document that you want to open does any information appear? Have you tried a right click on the file and then selected 'open' from the list that appears? Just a couple of things to try which might provide more clues.
    Is the programme you are using Word? There could be a problem with that. Can you open Word on its own? - if you click on 'Start' there is a box at the bottom with 'start search' in it, have you put the document name in there and clicked search? Sorry if you have done all this and I appear to be treating you like someone who doesn't know some of this stuff - it's so difficult when you don't know how much someone can do on a computer.
    Will not be about for a couple of hours now so good luck and will have a look to see your answers when I get back. Hopefully someone else will have had a look at the problem and come up with a solution by then.
  9. normanandsue
    Dec 31, 2010
    1,311
    4,266
    Thanks Ken really appreciate your help, especially over a distance. Have compared your menu windo with min and it differs slightly, the main difference being there is no option of choosing an alternate system restore date.
    Norman.
    PS liked your exercise bike
    • Like Like x 1
  10. normanandsue
    Dec 31, 2010
    1,311
    4,266
    Ronnie,
    I appreciate your help; you are quite right to assume I have limited knowledge as I certainly do.
    My problem is whenever I try to access My Documents it opens - then when I select a file in the My Documents and click on it, Windows explorer finds a fault and closes.
    If I can remember the file name I want in My Documents and type it into the search I can enter my file, though after some time it is likely to find the Windows explorer error again and shut down.
    You are right I am using Microsfot Word, Excel and powerpoint, though the error is most active when I try to access a powerpoint file but not always.
    Many thanks
    Norman
  11. Munchie
    Jul 28, 2007
    8,571
    11,754
    Norman try this, start/computer then right click on your c drive then Properties then tools then checkthis drive for errors then schedule it and shut down and restart. Let it run it's course
    and see if it helps. After that my two brain cells have run out of energy, :cry:
  12. normanandsue
    Dec 31, 2010
    1,311
    4,266
    Ken,
    Many thanks - sorry to say that has not done the trick. Keep swinging and enjoying France.
    Norman
  13. normanandsue
    Dec 31, 2010
    1,311
    4,266
    Thanks Ronnie,
    Any further suggestions would be most helpful.
    Norman
  14. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
  15. RonnieJ
    Jun 30, 2009
    111
    74
    Thetford, Norfolk
    Are your problems sorted out now? Looks like they are judging from your last post. Hope all is OK now.
  16. normanandsue
    Dec 31, 2010
    1,311
    4,266
    Ronnie,
    Many thanks if only it was! I tried a diagnosis programme which like all diagnostic programmes told me I had corrupt files and would correct them if I paid £70
    If I could be certain they would, I would spend it but if not I would have wasted my money.
    I am convinced if I can carry out a system restore as far back as June the problem would be solved.
    So if you have any suggestions I would be grateful
    Norman
  17. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,824
    36,074
    Leicestershire
    How about.
    A Create a new folder, MY DOCS 2
    B Search for all files *.doc , *.xls, *.ppt etc
    C Copy the files to the new folder..
  18. Munchie
    Jul 28, 2007
    8,571
    11,754
    Norman, if you put your windows disc in there should be a "repair" function in which case you will not lose any files. Possible your Word disc has the same function.
    As an aside i never use my documents, I right click on the desktop and create new folders calling them "word" or "PDF" or whatever then I "save as" into those folders. :thumb:
  19. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,355
    9,798
    I note that nobody has suggested the obvious...... run the system file checker built into windows
    run the following from the command prompt, including the space
    sfc /scannow
  20. TheBig1
    Nov 27, 2011
    7,355
    9,798
    a little more info for those that dont know about SFC
