Completely flat
Discussion in 'Motorhome Chat' started by highwayman, Apr 14, 2012.
  1. highwayman
    highwayman Funster Life Member
    Jul 31, 2007
    858
    476
    Kent coast
    Hi Folks
    Got a new leisure battery, and somehow turned the charger off in the van :Doh:
    We ended up with a completely flat battery that wouldn't even iluminate a light let along move the needle on the battery gauge.
    Now the thing-is it charged up ok and has held a charge all winter albeit not to the top of the gauge, but should i trust-it or not??
    I'm leaning towards not,:cry: but at less than a year old and a cost of £100 i don't want to throw it away. Dunno what to do so i thought i'd ask the experts.
    Another thing, to connect another battery and double our capacity it's positive to positive and negative to negative isn't-it??
    cheers nige
    • Like it Like it x 1
  2. darklord
    darklord Read Only Funster
    Apr 28, 2011
    1,241
    1,243
    essex
    You are correct in the pos to pos etc bit. You need to test the battery, if you connect a duff one to a good one, you;ll not really gain anything and could cause problems. Did the battery have a warranty? if so, it was probably two years........? Halfords will do a drop test on if for you, or you could do a simple test by turning stuff on and seeing how long it lasts....good luck.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,121
    17,789
    YO11 2BD
    if its still holding charge it sounds like you may be Ok.
    you could do a load test with a known load to be sure using something like a 50watt car spotlight bulb and a digital voltage meter.
    a regular charger wont fully charge the battery but it will be close enough to test.
    let the battery stand 'off charge' for a couple of hours.
    connect the meter to the battery and check voltage (should be 12.6v/12.7v), then connect the bulb as well.
    check the meter regularly.
    a 50w load should bring a 110ah battery voltage down to 12v (50% charge) in around 13 hours.
    if the battery is knackered the time will be greatly reduced.
