Cold footwell. (1 Viewer)
Jonesee
5
Pencoed S Wales
Bessacarr E562 2013
30 years
Hi everyone the sun is shinning in S Wales but rain is on its way. Have had 2 Kontiki's both with double floors no problem with cold spots in habitation door footwell. Have now got a Besssacarr e562, with Alde heating, footwell really cold, seems the footwell step is only single skin. Has anybody had the same problem? any remedies? let me know. Thanks all. Jonesee.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
There is possibly a large ventilation grille in the footwell as it is the lowest point in the habitation. My E560 has one.
Photo4x4
371
873
Scottish Highlands
Coachbuilt with over cab
Newbie
I this not there as a safety measure so that any escaped LPG gas will 'leak' out of the habitation area?
KH
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
That has always been my assumption, it is also the source of noise when driving in the rain as water in the gutter splashes up onto the footwell. I have covered it once, basically stuffed the dog's towel down there, it was a sub-zero night and blowing a full gale in the highlands.
TheBig1
17,630
43,252
many vans just have a moulded plastic footwell with no insulation. some 25mm kingspan can be cut to size and bonded on the back and underneath using sikaflex
Jonesee
Jonesee
5
Pencoed S Wales
Bessacarr E562 2013
30 years
Many thanks all for your replies. There is no vent in the footwell only a small foot light. Will try and bond some kingspan to it to as TheBig1 suggests and will keep you posted. ......Jonesee
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
All these kind of things make you wonder if the makers actually try out one of their own vans in the cold to find these bits and pieces that detract from the quality of the build. My old Chausson was abysmal draughts, and cold spots all over it . The French may not use their vans in Winter.
TheBig1
17,630
43,252
i know the designers at bailey used to test their caravan designs in real life tests, not just in the factory. but other than a few low volume pvc converters, i dont know of any other designers that have even slept in one of their motorhome creations
DBK
18,022
48,089
Plympton, Devon
PVC, Murvi Morocco
I can understand why it has a cold footwell but I'm not sure why it is a problem. Have you been banished to the naughty step?
Try sleeping on the bed. :)
Jonesee
Jonesee
5
Pencoed S Wales
Bessacarr E562 2013
30 years
Nice one. Swift advertise the motorhome as having attained grade 3 with respect to heating and no cold spots. Must have had a duvet on the footwell. Thanks.
Dec 12, 2010
5,409
21,557
Cumbria
since 2011
The footwell on our Renault isn't the problem, it's the door cards. We've actually woken up to find frozen condensation on them as we tend not to run the heating overnight. I keep threatening to pry them off and fit some insulation, but you know...........:whistle:
Jonesee
Jonesee
5
Pencoed S Wales
Bessacarr E562 2013
30 years
Hi Jockaneezer, no definitely the footwell itself, no condensation on the habitation door.....Jonesee
Gellyneck
9,212
18,188
Scotland
More than toes wet now!
Is the draught in the footwell not from the original (Fiat) designed ventilation vent under \ behind the cab passenger floor. This is there to aid ventilation on Ducato cab \ chassis models and convertors don't block this up despite it not being needed when you stick a coachbuilt body on the back!
You can buy a clip on vent cover from a Fiat Professional dealer (don't have the part number with me) for around a tenner or search on here for a post from (I think) @Techno who has done a diy version.
Maybe got this wrong as you say hab door but maybe worth a look see?
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
You need a pair of Acme (patented) foot warming slippers. (y)(y)(y)
Sep 11, 2014
1,012
3,482
West Sussex
None
Since 2013
The hab footwell in our Swift Sundance was a major problem with cold air blowing a hooli.
We started off stuffing a cushion down there and it helped. We've now taped up the vent and also made a full length curtain which we pull across at night. These measures have pretty much cured it and made the hab area much cosier.
Jonesee
Jonesee
5
Pencoed S Wales
Bessacarr E562 2013
30 years
Many thanks all for your replies and suggestions. Habitation door is the door into the motorhome not the cab doors, that area is always cooler due door seals and vents....Jonesee
Jan 11, 2010
2,746
9,566
Chester
Auto-trail
Well that`s our 13th year & still loving it.
As mentioned by TheBig1 moulded plastic footwells with no insulation are the culprit for cold draughts, in the auto trail we have the draught in cold winds from this area around the footwell is freezing, we have cut a board to go over the top, with the welcome mat covering that the cold area is pretty much sealed.
Still a bloody nuisance and makes a total farce of the supposedly fully insulated claim by the builders, also if you have a look at the EHU socket in the habitation wall, the uninsulated wall around the socket is another cold spot.
The cab areas are no warmer than a tent, how people get on were they use the cab area as part go the seating plan is a mystery to us.
