Clutch quote
Discussion in 'Motorhome Chat' started by sally47, Jan 20, 2016.
  1. sally47
    sally47 Funster
    Apr 29, 2014
    179
    65
    Just had van serviced chieftain tag 2.8 fiat service Fine BUT needed new turbo only done 16000 miles anyway off to France March so thought might as well have a remap while its in then they phoned up clutch is fine but would not like to remap as it would probably kill the clutch within three months so now looking to have new one fitted anyone know the cost please been quoted £650
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,047
    13,908
    Bolsover, Derbyshire
    no idea how much it should be, but parts and fitting sounds decent enough price
    I am more interested in the turbo, having just been told part alone is £1400 + VAT for my Mercedes Hymer, fitting is adding about the same again due to access, your clutch sounds positively cheap :)
  3. sally47
    sally47 Funster
    Apr 29, 2014
    179
    65
    Turbo reconditioned at £275 plus fitting
    • Like it Like it x 1
    • Informative Informative x 1
  4. Serendipitous
    Serendipitous Funster
    Aug 4, 2012
    347
    285
    Devizes
    At £650 snap there hands off. Cost best part of £1200 for a dual mass flywheel and clutch on our 3.0ltr ducato comfortmatic.
    Do you really need a remap?
  5. sally47
    sally47 Funster
    Apr 29, 2014
    179
    65
    Don't think I do now with new turbo
  6. GWAYGWAY
    GWAYGWAY Funster
    Sep 6, 2014
    2,235
    1,606
    Dover
    Who said it needs a new turbo at 16000 miles? They should last a lot longer than that 100000 is more like a minimum. Do you rev it and the stop the engine to starve it of oil? Get a second opinion from a turbo specialist BEFORE going for it.
    • Like it Like it x 2
  7. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,260
    622
    Just replaced clutch on my 2.8jtd (not a duel mass) £85 for Valeo clutch, £30 for a slave cylinder. Full days labour for fitting.
  8. Charlie
    Charlie Funster
    May 16, 2015
    2,544
    3,024
    I think what they are saying is doing a remap may put to much strain on the clutch...
    From previous threads on this engine / transmission it seems the clutch is a weak spot. So asking it to cope with extra power and torque could make it slip and eventually fail.
    Without physically examining the clutch components it is not possible to say how good or bad the clutch is. It is possible to load test a clutch by putting it under undue and not normal strain but doing so is not advisable as it could bugger it.
    In short the garage are probably just covering their arses as they wont want you complaining if the clutch goes after a re map.
  9. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,736
    3,384
    Cumbria
    Did they say it was going to be a heavy duty clutch ? Changing it for what's already fitted as standard would be pointless I reckon.
  10. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,260
    622
    Don't think there's such a thing.
  11. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,736
    3,384
    Cumbria
    That's what I was thinking, think someone on here had a remap on their Fiat and went through a couple of clutches :(
  12. Steve
    Steve Funster Life Member
    May 8, 2013
    1,589
    1,875
    Compton Berkshire
    2.8 jtd had mine done by mr clutch £400
    been remaped pulls much better. Looked at a hd cover but for what ever reason no such thing. remember to drive lightly in low gears or spin wheels
  13. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,260
    622
    Had mine remapped 170bhp, clutch did slip very occasionally but still drove to Spain and back, just had new one fitted. 60,000 miles on clock.
  14. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,961
    12,252
    Plympton, Devon
    I agree, it shouldn't need replacing unless it has been abused or starved of oil.
    Always idle the engine for a few minutes if the engine has been working, for example after driving on a motorway or in hilly country. I don't know the engine but if it has one they need to replace the oil feed pipe if the turbo is to be changed. It could be clogged with frazzled oil.
  15. Bacchus
    Bacchus Banned 1 month
    Jul 27, 2015
    423
    4,288
    Staines
    Trying to think of a good clutch quote, the best I can do is from Julius Ceasar
    Cry "Havoc," and let slip the cogs of war...
    [edit] the clutch on my old hymer was about £650 including having the flywheel skimmed for balance, although I would doubt that this compares with a more modern vehicle[/edit]
  16. Boringfrog
    Boringfrog Funster
    Jul 13, 2008
    1,260
    622
    "Slip sliding away, slip sliding away
    You know the nearer your destination, the more you slip sliding away"
  17. colinw
    colinw Read Only Funster
    Feb 1, 2015
    525
    306
    Bolton , Lancs.
    What is the difference between the clutches fitted in the fiat 2.3 litre 110 , 130 , 150 bhp engines ?
    A remap can be done to eliminate flat spots that are there due to emissions or noise regulations . any gains in bhp can be regulated with your right foot , therefore not spinning the wheels or slipping the clutch .
    When the time comes , change a dual mass flywheel with an ordinary one . A driver of a new merc sprinter I know has had 3 clutches under warranty , now replaced with a solid one by merc themselves .
  18. Charlie
    Charlie Funster
    May 16, 2015
    2,544
    3,024
    I dont think people here will be spinning the wheels ! Slipping the clutch perhaps ...
    It is possible for a clutch to start slipping under load when in gear and without the pedal being depressed at all. A case of the torque being more than the grip of the components. IE the driven plate starts to loose its grip on the flywheel due to too much load.
    I am all for re maps as they usually give a far better drive experience but it does seem that the clutches on this particular set up are at the limits with no tuning..
    Solid clutches are brilliant on some vehicles but horrendous on others. On some it can mean a heavier pedal and or a less smooth take up due to the way a dual mass flywheel absorbs vibration. But it really does vary from vehicle to vehicle.
Similar Threads
  1. Feltwell
    25
    1,152
