Clonk! (1 Viewer)
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Any clever bike types here???:thumb:
This is the bicycle bike, most of the time the faster/more load applied to the peddles produces a rythmic CLONK (caps 'cos it's loud!) that sounds kinda like some loon following me a belting the frame with a lump hammer.
It sounds most like it's coming from the rear gear assembly, 7 speed/gears and I can feel it through the frame but nothings touching/fouling anywhere. Bikes only a couple of years old, any thoughts?
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Hi it sounds like the gudgeon pin is loose or worn (holds pedals in position) take off the pedal arms examine grease and replace.:thumb: of course I could be wrong :ROFLMAO:
terry
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
First point of call is the pedal crank bearings, rock pedals to test, there should be no play, even if there is no play it could be the early signs of bearing failure, play will eventually become evident, cant think of anything else that would cause a heavy CLONK as you describe
Geo
Andy 01424
154
Hastings East Sussex
RV soon!
0 but lived in static for 2yrs
Or the Chain is slipping on the gears if this happens during change and keeps trying to go to nex gear:thumb:
Dodgey
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Terry,
Gudgeon pin?....Cotter pin, it's the other type (can't remember what it's called) but no can't be that, mad push biker in my youth and remember the cotter pin shenanegans well, one bike just ate 'em, never did figure out why...
Geo,
Crank bearings, doesn't sound as though that's where the problem is though I must admit that was my first choice. No decernable movment as yet, might have to bite the bullet and strip the bugger and see. It's only a cheapy but I don't really want to replace at the mo, still seeing exactly how much use it's going to get as to how much to spend next time, that and have you seen modern bikes, hydralic disk brakes, 27 gears, adjustable suspension, toys toys toys:thumb::ROFLMAO:
Cheers for the replies guys, any more?
Dodgey
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Good idea but no chance, anal here has the gears set perfect, no slip and bang on adjustment.
johnsandywhite
1,720
19
Doncaster/Spain
'A' Class RV &
:Smile: Hi Dodgey. I have the same problem with the Mountain Bike I bought from Walmarts 4 years ago. It has almost always done it. I believe it is the Crank Bearings. When I run Oil into the Crank it quietens down for a period before the sound returns. :RollEyes:
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Gudgeon pin?....Cotter pin :ROFLMAO: OK I will settle for cotter pin :thumb:
either way it looks like you are going to have to strip it down :ROFLMAO: like it or not :Doh:
terry
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
If it is more or less every revolution of the peddle,, most probably what used to be the cotter pin,,, but on modern bikes you have an allen key on the end of the shaft (Pedal crank arm),, these are splined or square,, might need nipping up,, if it is the spline type whip it off as if it has been doing it for any length of time a splines might be worn on crank arm,,
Modern bikes the cranks are alluminium and the shaft is steel,, hence the splines being/getting worn.
The other alternative, on your gear wheel/cluster,,, if it happens in a particular gear,, it may have a crack on the thread on one particular gear wheel... 5/6/7 gears are made up of individual gears/teeth and they in turn are threaded onto a rachet body,, so you can remove sets of gear teeth and put what ever combination of gearing on that suits you,,
If I remember correctly the threads are the oposite of the norm,, so as you do not unscrew when peddling.. bear this in mind if it is this and when replacing gear,,
Think they are that cheap if it is this probably not worth the bother and just buy a new complete set..
Apr 29, 2009
2,321
1,991
West Yorkshire...Halifax
Vanless....BUT....!!!!
Remove the pedal crank and check the spindle you possibly have a cracked spindle..if not pack it with grease that should cure it
Frank772
41
Warwickshire
none yet
none
May be worth looking to see if the L/h crank is bent (by dropping the bike) and
hitting the chain stay.
johng
587
Kent/Sussex UK
1984 C ClassGMC
seems a harsh way to check that, Frank ::bigsmile: welcome
I would have said bottom bracket bearings, or what is now in place of the gudgeons, usually a square shaft that now has worn cranks on..
as said above a few times :RollEyes:
John H
253
24
Anglesey
coachbuilt
3rd year
It could be a damaged or kinked link on the chain, or a damaged tooth on the crank?
John
Frank772
41
Warwickshire
none yet
none
Sorry I should have written caused by dropping the bike
:Blush:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
:Blush:
Welcome to the FUN site Frank, it made me smile, written like a seasoned Funster :thumb:
Geo
cyclingdoglucy
98
lancashire
retired vehicle
retired 4 months
bottom bracket
just a educated guess is that the bottom bracket wants removeing & a sealed bottom brkt put in its place. you will have to remove the cranks & one of the bottom brkt cups has a left hand thread/:Doh:
Dodgey
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
chuck it in a skip and buy a TOAD !!!!!!!! :ROFLMAO::ROFLMAO:
Daft bugger:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
The gold stars are looking like going to the crank bearing camp. Stripped down and piece of randon plactic in there, nothing to do with anything, next to no grease, rough bearings and some wierd 'lumps' on one of the bearing cups...
New bearings, a quicky with the die grinder/oiled wet and dry and new grease and hopefully smooooth piece and quiet again.
Cheers all!:thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Geo
Told Ya:RollEyes:
